Author Topic: temp sensor wire  (Read 4020 times)
Offline greenmonster
temp sensor wire
« on: December 23, 2009, 04:55:14 pm »
I have a 75 k10 and I hooked up the factory temp gauge.The plug is missing from the end of the wire.Does anyone know where I can buy the plug that fits the sensor.
Offline 4x4orbust
Re: temp sensor wire
« Reply #1 on: December 23, 2009, 05:38:17 pm »
i just used a female electrical connector, works fine!    you are talking about the connector on the engine, right?
« Reply #2 on: December 23, 2009, 08:19:11 pm »
Yes the connector on the engine,but I have a gauge and not a light.The sensor has a round stub sticking out that I have to plug into.
« Reply #3 on: December 23, 2009, 10:29:33 pm »
4x4orbust showed you the correct connector. It's just a female spade.
« Reply #4 on: December 24, 2009, 05:24:24 am »
This is the sensor I have.
Offline Longshot379
« Reply #5 on: December 24, 2009, 06:10:01 am »
The female spade connector will slide over the end from the side.
« Reply #6 on: December 24, 2009, 06:14:31 am »
Oh! Ok,sounds like a plan.I'll give it a try.Thanx for the help.
