Author Topic: 73-87 Door Shell Differences and Door component info/swapability  (Read 77871 times)
« on: December 28, 2009, 01:19:03 pm »
GM doors from 73-76 were not available with power windows and they have short door panels and the window cranks are shorter.  Starting in 1977 power windows and locks were available and the inner door skin was change to accomplish this.  Below are the differences in the door panels
You can purchase these here in our store: Note shipping charges are not inlcuded
1973-76 Front Door shells
1977-87(91)Front Door shells
This is a 73-76
This is a 77-91
« Last Edit: December 06, 2023, 07:28:36 pm by Captkaos »
Re: 73-87 Door Shell Differences
« Reply #1 on: April 10, 2013, 11:45:51 pm »
This is the Technical topic on the door shell differences: http://forum.73-87chevytrucks.com/smforum/index.php?topic=3147.0
1973-76 – No provision for power windows, short door panels covering only the upper portion, requires short stalk regulators.
1977-91 – Power window provisions, extra holes for mounting power regulator, full door panels with lower carpeting, long stalk regulators.
Note items with links take you to our online catalog where you can purchase these items
Door Panels  http://forum.73-87chevytrucks.com/smforum/index.php/topic,25957
The 73-76 door panels can only be used on 73-76 doors unless you don't mind drilling new holes and filling in all the old holes.
The biggest being the large 2 at the bottom where the power motor bolts down (see above link)
77-80 and 81-87(91) panels “can” be used on any doors, but require the correct regulator (77-87(91)) the correct specific door handle (77-80 or 81-91)and new holes would need to be drilled.
Regulators:  http://forum.73-87chevytrucks.com/smforum/index.php/topic,23598.msg196819.html#msg196819
Manual:
The early 1973 doors won't accept the 77-up regulator rollers.
The 1973 Front Door Window Regulator  has a much smaller roller on them and is specific to that year, you would have to change out the roller to use them on anything else, and the lower door track is the culprit.  Note: some early 1974’s had these smaller rollers, check to be sure.
The 1974-76 Front Door Window Regulator  which are manual ONLY have a shorter window stalk crank and therefore cannot be used with the 77-87(91) door panels
On the 1977-87(91) Front Door MANUAL Window Regulator the window stalk crank is much longer than the 73-76 version.  Although they can be used with the 74-76 doors, they will have a large gap after the door panel stops.
Power:
1977-80 power regulators use the larger more powerful window motor  These can be used on any 1977-1991 door, but if you want to put them on the 1974-1976 door plan to make some new holes and modifications to make them work.
The 1977-87(91) Front Door Power Window Regulators  use the smaller window motor. These can be used on any 1977-1991 door, but if you want to put them on the 1974-1976 door plan to make some new holes and modifications to make them work.
Vent windows: http://forum.73-87chevytrucks.com/smforum/index.php?topic=27075.0
There are three styles of vent windows, all of them will interchange, BUT the later model ones won’t have the extra mounting hole like the early ones.
1973-1980 – Non locking glass handle, 2 bolts on the vertical surface of the door. (visit our store here for 73-80 gasket
1981-1985 – Locking glass handle, 1 bolt on the vertical surface of the door, 2 piece Seal. (visit our store here for 81-85 gasket
1985-1991 – Locking glass handle, 1 bolt on the vertical surface of the door. 1 piece seal. (visit our store here for 85-91 gasket
Door Handles:  http://forum.73-87chevytrucks.com/smforum/index.php/topic,25956
1973-1976 inside Door handles – thin with a curved tip, centered in the mount.  Will only work with related door panels.
1977-1980 Inner Door Handles – Thick(wide) with a curved tip, centered in the mount.  Will only work with related door panels
1981-1987(91) Inner Door Handles – Thin and straight, offset to the bottom.   Will only work with related door panels
Glass thickness:  http://forum.73-87chevytrucks.com/smforum/index.php/topic,23600.0.html
There are 2  different set/thickness of glass used.
1973-1980 was the thicker version
1981-1991 was the thinner version
Complete door assemblies removing from the hinges will swap to any year truck regardless of year.  So you can put 1973 doors on a 1991 truck and vice versa, 1977 on a 1973 and vice versa.  Suburban FRONT doors and Blazer doors from 1976-1991 will swap to pickups (there is no difference) in their entirety also.
« Last Edit: December 06, 2023, 07:54:36 pm by Captkaos »
