cleaning inside of rear differentail
Topic: cleaning inside of rear differentail (Read 8839 times)
chronos
December 30, 2009, 01:01:01 pm »
How can I go about cleaning inside of rear differentail
before putting cover back on?
Also what should I use to seal the cover back on , gasket or rtv?
Thanks
Re: cleaning inside of rear differentail
December 30, 2009, 02:02:02 pm »
Wipe it out. You can use brake clean. Use the right stuff by permatex.
⌠ŻŻŻŻŻ' [☼===☼]
1980c10
December 30, 2009, 08:35:19 pm »
No gasket and what vile said and watch for leaks for a few weeks or so.
chronos
December 30, 2009, 09:06:54 pm »
Thanks , I can get "Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker"
here is all I can find (I'm in CANADA) I assume this will be OK?
Got the brake cleaner today
Mr Diesel
Aaron
January 01, 2010, 12:14:42 pm »
Quote
I use this for just about everything that had a gasket. Works great, cheaper, and lasts longer.
1976 C20 Crewcab, 6.2L/SM465
1982 K30 Crewcab , 427TD/TH400
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
1986 K10 350/400. 1989 K30 cab/chassis 454/SM465
chronos
January 02, 2010, 03:37:38 pm »
Great,I will pick some of that up today.
I have a 1986 10 bolt open rear in this truck.
How much fluid does it hold? Can I put the fluid in through the vent tube?
January 02, 2010, 03:45:57 pm »
No you fill it through the fill plug.
⌠ŻŻŻŻŻ' [☼===☼]
malibu795
January 03, 2010, 03:32:52 pm »
had a rep from perma tex come to school last week..
they ultra cooper is strong enough to make exhaust gaskets..... lay a bead.. let is dry/skin over then install...
adam wildman
75 K25 383/400
SUX2BU99
January 06, 2010, 10:29:25 am »
And it's probably much easier to find a RTV product at various stores and times than it is to buy a gasket from a parts store.
That all said, on my truck, each time I've had a drip from the rear diff, it's been when sealant was used and not a gasket. The two times I've used gaskets and my chrome cover, no leaks. Even when a specialty differential shop was working on my truck, they used sealant and I had a leak. It allllll depends on how good you apply it and clean the surface it's sealing against.
Jim Rockford
Banned
January 08, 2010, 09:07:12 pm »
I always buy a gasket, then smear axle grease on one side of the gasket, that way next time i take it off it doesn't stick.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Layne
January 08, 2010, 09:08:30 pm »
I put a light coating of rtv on the gasket then put it on. That's me, though
January 09, 2010, 02:30:48 pm »
Layne, you're defeating the purpose of the gasket when you do that so why use the gasket? RTV does not ad too the sealability to a gasket. If you like using a gasket, scrap the RTV and use a gasket adhesive sealant.
⌠ŻŻŻŻŻ' [☼===☼]
Layne
January 09, 2010, 06:58:43 pm »
So it's one or the other? I figured rtv + gasket = no leak.
January 10, 2010, 11:44:45 am »
Good RTV = no leak and no need for gasket.
⌠ŻŻŻŻŻ' [☼===☼]
Layne
January 11, 2010, 11:41:03 am »
Ok thanks. I only use "the right stuff" that you guys recommend anyway, so being extra picky actually makes it worse.
