Author Topic: 84 6.2L Diesel Sending Unit  (Read 16785 times)
Offline C-Moore502
« on: January 04, 2010, 09:50:56 am »
I wanted to know if I have to put the 2 outlet that cost an extra $100 or if I can use the other 3 outlet unit.   says the 2 outlet but I wanted to be sure. Thanks.
84' K20 6.2L "The Duke"
Re: 84 6.2L Diesel Sending Unit
« Reply #1 on: January 04, 2010, 11:04:08 am »
From where?  The Diesel should be a 2 outlet.  If you block off the 3rd one it should work though.
Offline C-Moore502
« Reply #2 on: January 04, 2010, 11:49:15 am »
I was looking around for a good price.
« Last Edit: January 04, 2010, 12:02:16 pm by Captkaos »
Offline Mr Diesel
  • Aaron
« Reply #3 on: January 07, 2010, 11:20:47 pm »
I bought mine here for about $70 each plus shipping.
http://www.quantaproducts.com/products.asp?dept=332&pagenumber=2&sort_on=&sort_by=
The one they show has the third port for removing water from the tanks. You can just block it off. The later models used only 2 ports.
« Last Edit: January 07, 2010, 11:22:32 pm by Mr Diesel »
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
