Author Topic: need help with a basic part list for 383 build ( first time builder )  (Read 5136 times)
Offline 305chevy c-10
hi  after finally facing the music about my weak 305 and just being feed up with not having a beast under my hood ...c10 with a beast under hood is something that always got my attention .....I've decided to take on a project of building a 383 .sure i can get a builder to do it but it nothing like the joy of knowing u did it ....so here i am ....here is what i need from my Chevy family ........a basic but complete  engine build part list ...here is what i know ...........350 block (bored and cleared for a 3.75 crank ) ...3.75 crank...5.7 rods..piston to match bore of block ...cam...timing set ...heads (gonna buy these fully assembled)..oil pump and pan ...intake and carb ......now the small stuff i dint know about like bearings ,bushings etc...........................because I'm gonna buy pieces at a time to do this build so i need to know all parts needed so they will be compatable ...or is a book that will tell me every part for this build .........this is not gonna be a race truck just a nice  street truck 375-400 torque ..you know that tire shredding power ....thanks guys
Heartbeat of America yesterday's cheverolet
18T5C10
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: need help with a basic part list for 383 build ( first time builder )
« Reply #1 on: January 08, 2010, 09:36:52 pm »
Get one or two of David Vizard's books...
http://www.amazon.com/David-Vizard/e/B001JOWD4M/ref=ntt_athr_dp_pel_1
Just remember to get a 400 ci crank and  flexplate (flywheel).  Pistons, rings, cam, cam bearings, ring compressor (to compress the rings when placing in the block bores, timing chain/gears, h2o pump, main bearing, rod bearings, oil pump, gasket set, new egr valve, new TVS, t-stadt, new belts, hoses, fuel pump.
my 383 www.delbridge.net/install
« Reply #2 on: January 09, 2010, 01:09:12 pm »
Check out Summit Racing and start putting a list together. You essentially just need the parts you would with any overhaul but you are putting in a different rotating assembly and a piston with a different compression height. You will have to relieve the block to accomodate the new crank and have it bored/finish honed. There are 2 piece and 1 piece rear main seal engines too so you'll need to know that.
Offline cdpence69
« Reply #3 on: January 11, 2010, 09:20:21 pm »
get u a 400 crank and a old elex plate out of an old monte carlo make sure u get a 400 cranlk like ouutta a grain truck they alot better 300h dubble hump head 5.7 shaved rods and a camshaft
« Reply #4 on: January 11, 2010, 11:22:11 pm »
Most places such as Summit or Jeggs sell a kit just for this purpose. In the long run a stroker kit will probably be cheaper than piece mealing it.
Offline autorepr
« Reply #5 on: January 12, 2010, 07:09:03 am »
Cool! Good luck with your project. There's no replacement for displacement for making power and more power is always better. Try a place called Competition Products. They have kits available for several different sizes, 355, 377, 383,406. They also have heads, cams, intakes and just about everything else.
www.competitionproducts.com    There in WI.
« Last Edit: January 12, 2010, 07:11:05 am by autorepr »
