Author Topic: having trouble starting 6.2 diesel  (Read 86775 times)
Offline gold84gmc
Re: having trouble starting 6.2 diesel
« Reply #45 on: January 13, 2010, 02:20:43 pm »
ok that makes sense
what if the test like doesnt reach the battery and i dont have a jumper wire
92 buick century custom 3.3L
Offline levisjohnson
« Reply #46 on: January 13, 2010, 03:40:25 pm »
Use a coat hanger
Levis
88 6.2L Diesel 3+3 3/4 ton
Offline gold84gmc
« Reply #47 on: January 13, 2010, 08:10:12 pm »
so can someone list the possibilities that could be causing it to turn over slowly and not starting?
Offline Donut
« Reply #48 on: January 13, 2010, 08:34:10 pm »
Bad/discharged battery(s)
bad connection somewhere
bad starter
Mid 20's for a high temp isn't helping.
Did the PO start the truck for you before you got it?  At least to verify it would start/run even if only for a few seconds.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #49 on: January 13, 2010, 08:42:24 pm »
I would make sure both bats are good. A week starter wouuld also cause that
Offline gold84gmc
« Reply #50 on: January 13, 2010, 08:49:47 pm »
yes he did start it for me...but he also had a charger(one on wheels) and the block heater plugged in...and it started right up and it stayed running
Offline Donut
« Reply #51 on: January 14, 2010, 06:29:02 am »
Can you get the truck into some place warm? (right now it's below 0)
Get both batteries tested.  iirc, they can both read 12v, but if one is "shorted" it's junk.  (load test)
check connections.
Don't get frustrated or overwhelmed, just because it's diesel doesn't mean it's from another planet.  ;)
« Last Edit: January 14, 2010, 06:35:18 am by Donut »
350/tbh350/np205
« Reply #52 on: January 14, 2010, 07:30:42 am »
Gold84,
this thread is all over the place. Start over,
#1 make sure you have charged batteries and good connections
#2 make sure you have fuel
#3 if it turns over really slow do a starter draw test. Since you go to school you should have access to an amp clamp.
Offline gold84gmc
« Reply #53 on: January 14, 2010, 09:15:15 am »
one battery is new and the other one isnt new but it should be good...ive put the charger on both and it doesnt change it all even when i put it on engine start
im going to take off the start and have it tested
and i think i have fuel because i opened the air bleed valve on the fuel filter and fuel came out and it has a full tank
and i put some anti-gel stuff in it...im starting to think that the starter is bad because ive put the charger on, tried jump starting it and nothing seems to help
it just seems like its not turning over fast enough for the engine to start
Offline gold84gmc
« Reply #54 on: January 14, 2010, 01:52:59 pm »
so i just went out and looked at the batteries...the new one is 730 CCA's and the other one that i put in is only 650 CCA's and the old one that was in the truck when i got it is also 650 CCA's...so do you think this is my problem? i need to get a more powerful battery?
« Reply #55 on: January 14, 2010, 02:52:53 pm »
I don't think its the bat. but eliminate that first then go from there test it then test the starter. I think that's your problem but make sure before you buy something you don't need
Offline gold84gmc
« Reply #56 on: January 14, 2010, 05:11:35 pm »
i think it was because of the battery because i took the batt out of my dads truck and that was 850 CCA and my truck turned over a lot faster and better
i couldnt get it started, but i think thats because i havent had it plugged in and it was -10 here this morning...so im going to get another battery
and i talked to a local garage and they said that both batteries need to be the same size (CCA's) with my dads 850 and my new 730 it seemed fine, and im not gonna spend another $200 on batteries seeing that i dont even have that money
« Reply #57 on: January 16, 2010, 12:01:00 am »
all you should have to replace is the one your dads is replacing. did you leave it plugged in over night again?
Offline gold84gmc
« Reply #58 on: January 16, 2010, 07:05:45 am »
last night i went and bought an 800 CCA battery, i kept it in a warm spot over night and im going to put it in this morning and try to start it...i have had it plugged in since noon yesterday so that should be all set
Offline Jim Rockford
  • Banned
« Reply #59 on: January 16, 2010, 07:59:58 am »
have someone check the battery voltage while you crank, If one goes below 10.5 volts its done for.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
