Author Topic: having trouble starting 6.2 diesel  (Read 86776 times)
Offline gold84gmc
Re: having trouble starting 6.2 diesel
« Reply #60 on: January 16, 2010, 11:27:24 am »
i put in the new batt in this morning and it started then stalled again....and then i couldnt get it started once again.
theres what looks to be a vacuum pump on the front of the engine and it has a pulley for the belt..i just noticed that the belt wasnt on there so the pump wasnt running...would this affect my engine as far as starting it or keeping it running?
92 buick century custom 3.3L
Offline Layne
« Reply #61 on: January 16, 2010, 12:19:12 pm »
Definitely! Get a belt for that. I've heard AIR is far more important for diesels than gas.
Offline gold84gmc
« Reply #62 on: January 16, 2010, 03:28:27 pm »
its not a separate v-belt or anything...i was thinking maybe i could put the belt on this pump instead of the ac compressor
Offline Donut
« Reply #63 on: January 16, 2010, 03:45:59 pm »
*shrugs* It's in front of you, not us.  Quit posting and get it running! ;)
The "shotgun" approach rarely ever works.
Crank-yes, no
fuel-yes, no
spark (glow-plug) yes, no
KISS rule
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline gold84gmc
« Reply #64 on: January 16, 2010, 07:01:36 pm »
crank-yes
fuel- im pretty sure
glow plugs- im pretty sure
Offline Donut
« Reply #65 on: January 16, 2010, 08:32:04 pm »
Run= No.
Pretty sure isn't quite there. ;)
350/tbh350/np205
Offline gold84gmc
« Reply #66 on: January 16, 2010, 09:00:50 pm »
haha ya i know
i might just end up selling to my friend because he said he would buy it...but i dont know yet
« Reply #67 on: January 17, 2010, 12:10:46 am »
some friend will he help you out with it? but i bet he knows whats wrong with it and wont help you out
Offline Donut
« Reply #68 on: January 17, 2010, 06:29:27 am »
I used to have friends like that Irish, there might be more truth to it than you think.
Gold, if you have to, step back and give it a break.  To me, it sounds like something simple, staring you in the face, you're just not seeing it.
Do you have a Chilton's?  IIRC, the small one for the 73-87 trucks didn't have much on the 6.2, but the big hardcover (I think it covered all makes) had more on the diesel.  (my brain might be fuzzy,  I haven't had my big Chiltons book since the 90's  :-\)
check here, maybe you can find some tips. (I actually think the link was posted earlier in this thread) [url]http://www.dieselplace.com/forum/index.php[url]
I was considering an oil burner for myself, but now I dunno...
350/tbh350/np205
« Reply #69 on: January 17, 2010, 06:45:51 am »
give it a blast of wd40 or something similar while cranking it.
Offline gold84gmc
« Reply #70 on: January 17, 2010, 08:01:46 am »
no he said he would buy it off of me
yes i have a haynes techbook that tells just about everything for the gm 5.7,6.2, and 6.5 diesel along with some ford diesels....really the only thing its helped me with is changing the water pump(did that yesterday) and bleeding the fuel system
do you mean spray wd40 in the intake? and on the air cleaner it says not to use starting fluid
« Reply #71 on: January 17, 2010, 10:12:00 am »
Cycle the glow plugs two times before trying to start it. If it doesn't start spray wd40 in the intake. Not a ton of it just enough to ensure you are getting fuel. If it fires you know you have a fuel delivery issue.
« Reply #72 on: January 17, 2010, 10:13:08 am »
And no do not use ether or starting fluid as it ignites way to easily for a diesel engine and you could do some serious engine damage.
Offline gold84gmc
« Reply #73 on: January 17, 2010, 10:17:21 am »
i cycled the plugs twice yesterday and thats when it started and when it stalled i tried doing it again and it wouldnt start...so youre saying i can use wd40 but i cant use starting fluid?
« Reply #74 on: January 17, 2010, 01:07:33 pm »
WD40 yes
Starting fluid/Ether NEVER!
can you crack open one of the injection lines going to the head and see if you are getting fuel there?
