Author Topic: having trouble starting 6.2 diesel  (Read 86776 times)
Offline gold84gmc
Re: having trouble starting 6.2 diesel
« Reply #90 on: January 24, 2010, 08:49:45 am »
ok ill take a video but im still not gonna keep it because i just like gas engines better than the detroit diesels, because i know alot more about them and i think theyre easier to work on.
thing with taking a video, i havent had the block heater pugged in all week
92 buick century custom 3.3L
Offline gold84gmc
Offline Donut
« Reply #92 on: January 24, 2010, 04:28:09 pm »
If I were cranking that slow, I wouldn't start either.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline Marc
« Reply #93 on: January 24, 2010, 05:53:01 pm »
I;d charge the batteries up as much as possible, and make good they are both good - one bad one will take out the good one.  Double check all battery connections and the connections to the starter and block.
« Reply #94 on: January 24, 2010, 06:05:44 pm »
Put a starter in it.
Offline Mr Diesel
  • Aaron
« Reply #95 on: January 24, 2010, 06:17:55 pm »
Turning over WAY too slow. It might turn over this slow if it is very cold and hasn't been plugged in, otherwise it is a bad battery connection, weak batteries, or weak starter.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline gold84gmc
« Reply #96 on: January 24, 2010, 09:40:13 pm »
so if it isnt the batteries or batt. connections then is it deffinatly the starter? i need to find out exactly what the problem because a guy would trade for another truck if i find out exactly whats wrong with it...i still need to find out about the stalling problem too
Offline bigwillie82
« Reply #97 on: January 25, 2010, 01:01:27 am »
is it an automatic or standard? i had an old f*#d that did the same thing nickle and dime me but in the end i drug it down the road and it fired right up.leave running and let it charge everything back up. and clean out.
Offline gold84gmc
« Reply #98 on: January 25, 2010, 06:17:26 am »
its an automatic and i dont even know what you just said haha
« Reply #99 on: January 25, 2010, 06:24:40 am »
He said he had a Ford that used to cost him a little here and a little more there. It was a standard, so he could have it pull started to get it going. If yours was a standard, you could attempt the same thing.
Offline gold84gmc
« Reply #100 on: January 25, 2010, 06:44:33 am »
oh if mine was manual then i probably wouldve tried doing that
Offline Donut
« Reply #101 on: January 25, 2010, 09:40:23 am »
Page 2- get the starter tested  ::) (that was 2 weeks ago)
350/tbh350/np205
Offline gold84gmc
« Reply #102 on: January 25, 2010, 10:01:59 am »
haha i know i know...its just everything is wet and its raining outside, i dont really feel like doing it today
« Reply #103 on: January 25, 2010, 12:43:22 pm »
Taking the starter out and testing it won't reveal much. You need to test current draw while it's installed. I would just replace it if you don't have the means.
Offline Mr Diesel
  • Aaron
« Reply #104 on: January 26, 2010, 08:19:48 am »
Don't replace the starter with a reman unit. It took me about 13 warranty replacements before I finally got one that was good(think they accidently gave me a new one). In one case one failed within 3 weeks, and another time the replacement turned over slower than the one I brought in for warranty. It isn't worth the headache. A brand new one costs about $100 more, but is worth every penny. Or look on ebay. They had a good selection of new ones last time I looked.
