Author Topic: heater control  (Read 9959 times)
Offline bowtieguy80
heater control
« on: January 14, 2010, 07:09:29 pm »
     Anyone know where to find a heater control panel for a '82 chev with ac? Mine is hopelessly wore out and a used one is probably not going to be much better.
Offline bowtieguy80
Re: heater control
« Reply #2 on: January 15, 2010, 07:08:45 pm »
     Thanks, Vile.
     Another option I was thinking about is that is it possible to swap my controller for one that fits an '83-'87? They seem to be cheaper and a better. Is it an easy swap or does it involve some more extensive swapping?
Offline Prong
Re: heater control
« Reply #3 on: January 15, 2010, 07:43:25 pm »
On a related note, I'm in need of the connector for the blower switch on my 79 (with factory A/C). I can only find the 83 and up flavor (4 pins in a straight line).
Mine looks like this:  |  |
Does anyone know where to find this connector at? If not, can I retrofit the 83 up switch and connector into my unit? If not, can I retrofit the newer panel into mine and have the vacuum lines and other connector on the vacuum head all work out?
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Re: heater control
« Reply #4 on: January 16, 2010, 01:01:11 am »
i would cut the wires and just add some female spade connectors what ever they are called if you have to.
Offline Prong
Re: heater control
« Reply #5 on: January 16, 2010, 03:26:05 am »
I'm trying to avoid the ghetto approach. I may see if I can find a decent one at the boneyard. However, I'd still appreciate any leads on a new one though.
Offline Prong
Re: heater control
« Reply #7 on: January 16, 2010, 10:42:12 pm »
Thanks a million Vile.
Re: heater control
« Reply #8 on: January 17, 2010, 06:47:35 am »
     Thanks, Vile.
$49 is cheap enough for a new controller. If you want to start swapping everything else around it's gunna cost you a lot more.
Offline bowtieguy80
Re: heater control
« Reply #9 on: January 25, 2010, 07:50:25 pm »
     The controler that you actually move with your hand is the piece that is wobbled out. I was looking for that part. Thanks.
