Author Topic: CARPET INSTALLATION  (Read 21024 times)
Offline SLOW-N-LOW74
CARPET INSTALLATION
« on: January 14, 2010, 09:32:16 pm »
Hey guys whats up,
I just got a carpet kit from ACC at a price i couldn't pass up and was going to install it and preping it up but i think i'm missing a piece on the upper firewall on the inside. Can you guys take pics of your carpet to see if im missing something  thanks guys in advance ;D
1974 CHEVY C-10 SHORT BED
1971 CHEVY SS CHEVELLE
1992 NISAN SENTRA (WITH A CHERRY BOMB)
DOUG
Re: CARPET INSTALLATION
« Reply #1 on: January 15, 2010, 12:23:48 am »
I dont have carpet in mine, so I cant help you but the carpet should meet up with the firewall pad.
Did you get the carpet locally?
« Reply #2 on: January 15, 2010, 01:05:53 am »
Hey beast, no i got it from an online store it also sells acc carpet but i got it for $129 i could look for my reciept  and give you the info if you want
DOUG
« Reply #3 on: January 15, 2010, 02:09:52 am »
I was just wondering if it were a local deal that I could get in on.
« Reply #4 on: January 15, 2010, 10:33:48 am »
You shouldn't be missing a piece as the carpet is all molded in one piece.  It should be oversized and trim to fit.  another words if it isn't bigger that the carpet you are pulling out, someone must have returned it either due to a coreshift when molding it, or they cut to much off of it.
The carpet should go up past the firewall insulation by at least 3-4" and should go past the door sill by at least that much.
I sell ACC carpet here: http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=7&Category_Code=FLRNG  It is $146 + about $21 to ship it anywhere.
« Reply #5 on: January 15, 2010, 10:39:57 am »
Cool thanks Capt. just wanted to be sure.  BTW sorry i had to save some cash
DOUG
« Reply #6 on: January 15, 2010, 11:51:37 am »
No problem.
« Reply #7 on: January 15, 2010, 01:56:54 pm »
Hey Capt, I saw two types of carpet for our trucks. Loop and cut pile. My truck is a 79 and it calls for cut pile. I would rather have loop carpet, is there a way around that?
« Reply #8 on: January 15, 2010, 11:29:11 pm »
73-74 used the same style carpet as the 67-72's loop pile.  75+ was cut pile.  You can order anything you want, but if you get a 79 in loop pile there is a charge and generally it is non returnable.  If that is what you really want though anything can be ordered.  Heck you can get it in Super Bright Blue if you want.
« Reply #9 on: January 16, 2010, 09:27:43 pm »
I will do ok without the super bright blue...Im actually going to convert the interior to gray. OK so if I order carpet for a 74, it wont fit in a 79? I have to custom order 79 with loop?
« Reply #10 on: January 17, 2010, 01:13:59 pm »
When you are ready to order, place it and there is a notes section, put what you want in there and If I have questions I will call you.  If you put what you want there will be a little more cost that I will have to add to it, but you will get what you want.
Offline chevyman72
  • 1987 C10 2WD 350cid 700r4
« Reply #11 on: January 17, 2010, 01:36:04 pm »
The capt will hook you up! He is working on mine now. He will help!
Chevyman
Offline okiesinmt
« Reply #12 on: January 17, 2010, 04:16:40 pm »
my 75 has loop carpet in it, does that mean it was a late 74 or early 75?
Sean
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #13 on: January 17, 2010, 06:20:14 pm »
Hey Capt I had a thought about my acc stuff.  I really love all the carpet and floormats.  Except for one thing.  They need an option to notch out the top left corner of the drivers floormat for the dimmer switch.  I'd have notched it myself except the mats have that embroidered edging, and I cant recreate that.   I have to pull the mat back daily to get it off the switch.  I think I may buy some of those mat anchor things to hold it in place.  Great quality stuff though.  I was impressed by the mats just because they were way heavier than anything at the parts stores, and I like the spikes on the underside too.
« Reply #14 on: January 17, 2010, 06:32:22 pm »
okiesinmt, yours would have to be a late 74 then.
Kenny,
Are you talking about the floor mats or the carpet.  Take a picture! I may can pass it on to them.
