Author Topic: can you name this sensor  (Read 6445 times)
Offline 1984gmchighserria
« on: January 17, 2010, 07:57:36 am »
Can any one tell me what sensor this is i think it is the water temp but i am not sure
Re: can you name this sensor
« Reply #1 on: January 17, 2010, 08:31:48 am »
Temperature sending unit for dash gauge. You are correct.
Offline eventhorizon66
« Reply #2 on: January 17, 2010, 01:10:17 pm »
LOL.  I was gonna say that's not a sensor, it's a stud.  Then I scrolled over.  Yep, water temp sender.
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: January 18, 2010, 01:37:09 am »
lol i kind of did the same thing. i was like what sensor ::)
but there are a couple different types of temp sender units that one "1" pin and one for a pig tail "2" pin
but if you go to autozone not sure about advace they will sell you the one i pictured it should come with the pigtail to sire it into your "1" pin
« Reply #4 on: January 18, 2010, 07:30:20 am »
don't confuse sensors with sending units..... Typically a sending unit relays direct information to the instrument panel cluster where as sensors relay information to the computer to process. Example:
Coolant temp sensor is used for fuel calibration primarily in open loop.
coolant temp sending unit is used only for the gauge.
« Reply #5 on: January 18, 2010, 01:34:41 pm »
thanks you guys my truck is almost done i just gotta do the timing i am going to try and get that done today
Offline Jim Rockford
  • Banned
« Reply #6 on: January 18, 2010, 09:33:53 pm »
Also remember there is different sending units for the gauge and the light.....
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
