Author Topic: Shock absorbers recommended for 1980 Chevrolet Blazer  (Read 6201 times)
Offline GUILLERMOARIAST
« on: January 22, 2010, 08:38:27 am »
Good day people, i have a 1980 Chevrolet Blazer 4wd, 250 cid engine.
It has a problem with suspension, it jumps and vibrate so much on unpaved roads, i thinks it happens because of the cheap shocks i bought. So i would like you to suggest me what type and brand of shocks will be suitable in order to solve this issue.
My truck has 31" tires and is 2" lifted over the normal height.
Thanks
____________________________________________
Guillermo Arias, Lima- Perú
Re: Shock absorbers recommended for 1980 Chevrolet Blazer
« Reply #1 on: January 22, 2010, 03:54:44 pm »
I have had good luck with Bilstiens.
« Reply #2 on: January 23, 2010, 04:34:34 am »
what type of lift, is it all springs or just blocks?
« Reply #3 on: January 23, 2010, 12:17:50 pm »
Check the front end first and your tires
Offline Chevalade
« Reply #4 on: January 23, 2010, 07:59:54 pm »
Bilstein 5100 series are great inexpensive shocks.
Offline heavychevy91
  • '86 Chevy K20
« Reply #5 on: February 01, 2010, 08:44:43 am »
I have had good luck with Monroes. Hows you tire pressure, sounds like it could be high
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: February 02, 2010, 03:30:45 pm »
I've been putting Monroe Gas-Magnums on all the trucks.  Never a problem and I've only needed one set per truck so far.
Offline 1980c10
« Reply #7 on: February 24, 2010, 09:17:15 pm »
I went with the top choice in monroes and they ride great
