Author Topic: caddy tailights  (Read 13913 times)
Offline 1983stepside
caddy tailights
« on: January 22, 2010, 11:04:48 am »
hi everyone, i have a question, and request, my question, has any one ever put caddy tail lights on a stepside, like maybe in the stake pockets, or in the roll pan any where, if so do you have any pics of it done, i want to put them in the steak pockets of my 83 stepside and would like to see if anyone has done anything like that for theres or someone they know any info would be great as well with pics thanks 8)
Offline 80stepsideguy
Re: caddy tailights
« Reply #1 on: January 22, 2010, 11:52:32 am »
This is what i was attempting to do to my truck as far as a rollpan, but the idiot welded them n the taillights didnt sit in to well so i couldnt use it n threw it out.So im going back to a rear bumper..
thanks
pat
It wouldve looked killer if it did work, i wouldve used the LED taillights
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5724.225
1998 Chevy 1500 S/B 2wd
Offline dv8customs
Re: caddy tailights
« Reply #2 on: January 22, 2010, 12:39:50 pm »
What went wrong with your install? I didn't follow that.
Offline 69byrd
  • Haulin!
Re: caddy tailights
« Reply #3 on: January 22, 2010, 01:13:50 pm »
I think that you would have to widen the stake pockets to fit the housings for the caddy lights.  You could use the leds like I did and put a caddy lens over it.  That would save you from widen the pocket.  Check with these guys they might already have something.  http://www.customclassic.com/
Re: caddy tailights
« Reply #5 on: January 23, 2010, 12:55:39 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9692.msg66058#msg66058
that looks good but i still want to have the tail gate, what would be the challenges of puting them in the rool pan on there side? i found a set that have the tail/turn/brake/reverse led light in the same light 8)
Offline MohterTrucker
Re: caddy tailights
« Reply #6 on: January 23, 2010, 01:44:50 am »
I wear pants w/ steak pockets when I go out to eat at expensive restaurants :D.
'83 GMC SWB 355: Iron Eagles 2.02/1.60's, 270/111LC, 1.6's, Edel/Weber 650, d/p mani, 1 5/8 longtubes, 700r4, and tired-ass factory rear leafs.
Re: caddy tailights
« Reply #7 on: January 23, 2010, 02:26:21 am »
83,
look at the link i provided a few posts ago and scroll down.I tried to lay them on their side in the rollpan but screwed up cause the housings were to close together when they got welded and the lights didnt sit in right...
Re: caddy tailights
« Reply #8 on: January 23, 2010, 11:48:11 am »
If you do use them make sure you install them with the lights to mock up exactly where you want the lamp. Then tack the buckets in place. Trace them with a sharpie and pop em back out. Cut em down and carefully weld them back in so you don't warp the pan. I would try to photoshop it first bc you might not like them.
Re: caddy tailights
« Reply #9 on: January 24, 2010, 09:37:09 pm »
i was thinking on useing the caddy lights because i dont want to use the stock ones, and i cant find anything tha has a reverse light, but the caddy lights i found they do, but if anyone has ideas for lights, and back up lights im open for ideas and pics thanks again guys for all the help and info your giving me i apprecate it 8)
Re: caddy tailights
« Reply #10 on: January 26, 2010, 02:53:05 am »
Right above the licence plate frame i was going to use a b/u light from a 89 grand am rear bumper and flush mount it ..
thanks
pat
Offline three8six
Re: caddy tailights
« Reply #11 on: January 26, 2010, 06:06:36 am »
I see AVS sells LED lights w/ backup lights but I've heard they are kinda sketchy with delivery and what they do and don't have in stock.
Re: caddy tailights
« Reply #12 on: January 26, 2010, 04:36:24 pm »
i also wanted to get led's and flush mount them in the front fenders where the oem marker lights are, avs sells the amber 4.5 inch light that i want to use and doing that i thought leaving the stock tail lights would look weird, like i started to customise my truck some and the quit half way, i thought of maybe lowering the stock tail light and its bracket as far as i can on the stake pocket, how would that look to you guys with the flush mount led's up front in the fenders? thanks let me know 8)
