Author Topic: Testing A/C relay  (Read 4955 times)
Offline Prong
Testing A/C relay
« on: January 24, 2010, 05:31:50 pm »
I'm in the process of putting the wiring back into my truck and have hit a snag. My blower motor will not operate via the dash switch. Also, the relay is making a loud buzzing sound when the fan switch is set to high. I've jumped the motor off the battery directly and it works fine that way. Is there a procedure to test the relay that an electrical novice can understand? The truck in question is a 79 with factory A/C. FYI, I replaced the relay and resistor last year, and I replaced the fan switch (in the dash) once this issue cropped up and no change.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Re: Testing A/C relay
« Reply #1 on: January 24, 2010, 05:50:05 pm »
First clean the connections and plug it back in. If it's buzzing tap on it lightly. To check the relay do you have a test light, a meter and some jumper wires?
Offline Prong
« Reply #2 on: January 25, 2010, 03:48:51 am »
I do have those things. You'll need to explain it like your talking to a 6 year old, because electrical is a big weakness of mine. The truck is at the bodyshop now, but I'll be there on Friday to tinker with it.
