Author Topic: Turbo 400 Driveshaft  (Read 5648 times)
Offline Texcuda
« on: January 25, 2010, 04:12:26 pm »
So, i'm swapping my 82 longbed from a turbo 350 to a turbo 400. Does anyone know if there's a 1 piece driveshaft for the turbo 400 in the aforementioned longbed? if so, what years, options would I need to be looking for to find 1 in a junkyard/craigslist? Eventually i'll have a custom 1 built after I make it a shortbed, but for now a stock one will work. Thanks
Re: Turbo 400 Driveshaft
« Reply #1 on: January 25, 2010, 06:17:07 pm »
It depends on the output of your TH400. Is the shaft bolted to the yoke? If so you'll need a slip yoke drive shaft. If you have the long tailshaft 400 you'll need just a solid one piece shaft. Try www.car-part.com
Offline Texcuda
« Reply #2 on: January 25, 2010, 08:02:20 pm »
it'll be slip yoke, i'm trying to find out if any factory longbeds came with a turbo 400 and 1 piece driveshaft? For that matter, it'll prob be a short tailshaft t400 as well. If not, I guess I can always shorten my existing 1 at home. It's not terribly difficult. Thanks
« Last Edit: January 25, 2010, 08:16:20 pm by Texcuda »
« Reply #3 on: January 25, 2010, 10:35:59 pm »
The short tail TH400 would be a two piece slip yoke driveshaft. The one piece driveshaft came with the long shaft TH400
Offline Texcuda
« Reply #4 on: January 26, 2010, 10:22:26 am »
kk. thx, guess i get to build one then.....  ;)
