Author Topic: Low beams not working  (Read 10654 times)
Offline Mr Diesel
  • Aaron
« on: January 26, 2010, 05:26:13 pm »
1983 GMC with quad headlights.
The other day the low beams stopped working. They DO work when I turn on the high beams, though. All 4 lights come on when I turn on the high beams, but when I dim them to low beams I get nothing. Replaced the dimmer switch on the floor and no change. What is confusing me is how they come on with the high beams. There is only one positive wire going to low beam so I can't figure out why that wire is hot only on high beam. Any ideas?
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Re: Low beams not working
« Reply #1 on: January 26, 2010, 11:37:54 pm »
Did you check the bulbs? They are dual filament
Offline Mr Diesel
  • Aaron
« Reply #2 on: January 27, 2010, 12:07:12 pm »
Yep. Swapped in another set of those too. Still nothing on low.
BTW, how can they be dual filament? I see only two wires, a green positive wire and a black ground wire on them. Wouldn't a dual filament need two positive wires?
« Last Edit: January 27, 2010, 12:09:30 pm by Mr Diesel »
Offline jaredts
« Reply #3 on: January 27, 2010, 02:29:26 pm »
I suspect Vile missed the quad headlights.  You should probably try and cipher the schematics in the tech section.  I don't know the circuit, but my guess would be that there's a low beam relay that's gone out and the high beam relay still works.
Offline Mr Diesel
  • Aaron
« Reply #4 on: January 27, 2010, 02:38:06 pm »
Hmm. I was under the assumption that there were no relays, just power running through the switch and to the lights. I will look at my schematics!
EDIT:
Okay, I figured it out. You were right, Vile. The low beam elements were burned out.
I was thinking the lower two lights were the low beams and the upper two high only, but it is the opposite. I had swapped out the lower two bulbs, not realizing those are high beam only. DUH. Now I know how quad headlights work. No wonder I was scratching my head all confused, I swapped out the wrong two headlights! Let's pretend this never happened...  :D
« Last Edit: January 27, 2010, 02:53:41 pm by Mr Diesel »
« Reply #5 on: January 27, 2010, 03:24:47 pm »
A lot of people make that mistake. Glad it fixed it. H4656 Dual filament peeps
