Author Topic: 700R4 shift correction kit and corvette servo  (Read 21356 times)
Offline krp33
« on: January 27, 2010, 09:59:26 am »
I have an 86 chevy 1/2 ton truck with a rebuilt 700R4 transmission. The transmission shifts fine but a little soft. There is nothing mechanically wrong with it now. I am planning on installing a Fairbanks superior K700-R4-V shift correction kit with the 0.471 boost valve. Does any body have any experience with this kit? I am also thinking about installing a corvette servo at the same time. What are some opinions on this mod? Will the part throttle shifts be to harsh? I don't want neck snapping shifts, just clean crisp positive shifting.
thanks.
Offline Layne
Re: 700R4 shift correction kit and corvette servo
« Reply #1 on: January 27, 2010, 12:00:30 pm »
I have corvette servos in my 700. Mines heavily modded, so I can't tell what they do alone. I like my tire chirping with a side of whiplash. ;)
« Reply #2 on: January 27, 2010, 04:38:48 pm »
I recommend putting the Vette Servo in.
Offline Layne
« Reply #3 on: January 27, 2010, 04:55:19 pm »
Capt, isn't that for a more positive 3-4 shift? I know it has a bigger bore for more line pressure or something...
Offline screamin86
« Reply #4 on: January 28, 2010, 05:19:00 pm »
They are for the 1-2 shift also. I have one in my 03 yukon its a 4l60e but the same as a 700 pretty much and the vette servo was one of the best mods ive done.
86 ta:lm7 hot cam boltons
« Reply #5 on: January 28, 2010, 05:44:24 pm »
Good for all shifts.
Offline Layne
« Reply #6 on: January 28, 2010, 06:21:35 pm »
So shift kit + servos = super pos. shifts, right?
« Reply #7 on: January 30, 2010, 08:07:55 pm »
yes.
« Reply #8 on: January 31, 2010, 07:27:42 am »
Use a trans-go kit. They are designed to make not just shift feel but actually better hold apply pressure and volume. The servo piston kit is used to enhance the shift feel when a band is applied. The intermediate band is applied to give you second gear. Try to remember this, a servo is used to apply a band. Since the 700R4 has one band the band is applied by this servo and gives you a 1-2 shift. The enhanced servo allows for positive displacement. Trans go also makes a kit for this.
« Reply #9 on: January 31, 2010, 08:39:22 am »
Trans-go p/n?
« Reply #10 on: January 31, 2010, 08:52:00 am »
It depends on what you want to do. Look on their website
http://www.transgo.com/index.html
Offline 4x4HighSierra
  • Sqaure body stud
« Reply #11 on: January 31, 2010, 11:29:21 pm »
i just rebuilt my 700R4 and while i was at it i put a transgo 700 junior shift kit in it and you can tell it has a much more solid second gear.    But i have a question of my own now.  When i was leaving work the other day i got on it and it shifted 1-2 and when it went for 3 it reved up for a split second and then shifted.  I know its doing it because the 2-4 band is not fully releasing when the 3-4 clutches are applying.  How do you fix this though.  I have heard a new seperater plate will do the job.  Is this true?
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
« Reply #12 on: February 01, 2010, 06:39:31 pm »
It's not because the band isn't releasing. Usually it's the accumulator spring, or the seperator plate is a cracked where the spring is seated.
« Reply #13 on: February 01, 2010, 08:42:30 pm »
Thank you
Offline krp33
« Reply #14 on: February 18, 2010, 08:42:43 am »
After talking with the rep from Superior-Fairbanks I decided to go with the K700-R4-V shift correction kit with 0.471 boost valve, a corvette 2nd apply servo, and their K034 billet 4th apply servo. According to the fairbanks rep, firmer shifts and better holding power in 4th gear for light towing. The shift correction kit is not a race type kit. It will correct some potential problems and firm up the shifts. I'll post my results when I get a chance to install it.
