Author Topic: Overdrive for 1981 dually 700r4? NV4500?  (Read 8511 times)
Offline frito-bandito
  • Hillbilly Deluxe
« on: January 28, 2010, 07:16:19 pm »
I have a 1981 Chevy dually with a 350 engine and currently a 4 spd manual trans. I would like to get overdrive in the truck. I would love to do the NV4500 swap, but then again an automatic trans would be cool too. Any thoughts anyone?
Re: Overdrive for 1981 dually 700r4? NV4500?
« Reply #1 on: January 30, 2010, 08:07:08 pm »
not exactly sure what you are asking but both are viable options.
  • Hillbilly Deluxe
« Reply #2 on: January 30, 2010, 08:19:49 pm »
Would a 700R4 be strong enough for a 1 ton that does occasional towing, and would I need a lock up torque converter. I would really like to do a NV4500 swap, but i'd do a 700R4 if its easier. Thanks
  • Hillbilly Deluxe
Is a 700R4 strong enough for a 1 ton dually?
« Reply #3 on: February 02, 2010, 07:58:37 pm »
I have a 1981 Chevy 1 ton single cab dually with a 350 engine. Is a 700R4 strong enough for this truck? I do moderate towing (mostly cars/trucks on a 16ft lowboy) but oits mostly a daily driver. I heard there is a difference in the earlier 700R4s and the later ones, is this true? Thanks everyone. :)
Offline Layne
Re: Is a 700R4 strong enough for a 1 ton dually?
« Reply #4 on: February 02, 2010, 08:18:15 pm »
There's a difference between the older and the newer ones. I think 86 is the turning year for the good trans. My opinion- I'm no expert- a good 700 will handle a 1 ton.
  • Hillbilly Deluxe
« Reply #5 on: February 02, 2010, 09:11:49 pm »
I am hoping that it would be strong enough, I want overdrive, and a NV4500 would be a tougher and more expensive swap, so maybe 700R4 is the way to go.
« Reply #6 on: February 02, 2010, 11:34:25 pm »
The only other affordable option is the 4L80E but I've built several 700R4's and put em behind big blocks without issue. A later 700R4/4L60 is a better buildable core. You will need upgrades however.
  • Hillbilly Deluxe
« Reply #7 on: February 03, 2010, 04:38:42 am »
Ok thanks, that's what I needed to know.
