Author Topic: stepside exhaust trouble  (Read 13151 times)
Offline 1981 ss chevy
« on: February 04, 2010, 08:58:16 am »
I just started to put full length hedmann headers on my 81 c10 stepside and after getting both headers in with ease i realize that the tranny cross member is only about 3ins away from the end of my header and once i put my reducer on it hits the crossmember making it impossible to hook up my exhaust what can i do?
Offline Da67goatman
  • Burban
Re: stepside exhaust trouble
« Reply #1 on: February 04, 2010, 09:25:16 am »
My buddy had the same problem and he ended up heating the headers with torches and bending them out of the way.  It's crude but it worked.
<Pitcrew>
« Reply #2 on: February 04, 2010, 09:58:10 am »
How low is your truck? DO you have pix? You can modify or move the crossmember or buy a dual exhaust crossmember. What trans do you have?
« Reply #3 on: February 04, 2010, 02:59:34 pm »
My truck is stock height it has a turbo 350 trans, sorry i can't get pics for you
« Reply #4 on: February 04, 2010, 05:42:59 pm »
if i heat them up wont the pipes want to kink them i'm out a set of headers
« Reply #5 on: February 04, 2010, 07:00:47 pm »
nvm guys i just cut the collector off and took out 4 inches which gain me enough room to put in an z looking bend lol but im pretty dang proud of myself!
Offline Donut
« Reply #6 on: February 06, 2010, 11:33:38 am »
iirc, one of the companies made an offset collector also.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #7 on: February 06, 2010, 01:10:29 pm »
sorry i cant get pics donut
Offline 355shortbed
« Reply #8 on: March 09, 2010, 10:00:23 pm »
ino this is a little old but, i just put the exhaust back on my 84 stepside. the crossmember is closer to the cab floor on the pass side of the truck and i had to do some dumb stuff with the pipes. i have the flowtech cheap headers on and they are angled down a little and not straight parralel to the floor, i bought the s bend pieces of pipe from headman that come off the collector and over the trans member. i ended up just running a straight piece of pipe under the crossmember cutting an angle to bring the end of pipe connecting to the reducer,up towards the bottom of the crossmember and using the s bend to raise up enuough to tuck the muffler (super 44s) up under the bed. worked alright
« Reply #9 on: March 12, 2010, 08:17:46 am »
355 short can i see some pics of what you did it kinda sounds like what I did
Offline Jacked85K10
« Reply #10 on: May 10, 2010, 12:35:17 am »
I believe he is referring to these. http://www.summitracing.com/parts/HED-18804/
Offline team39763
« Reply #11 on: May 11, 2010, 01:50:55 pm »
I used those S-extensions and they worked perfect for my truck.  My crossmember was also clearanced by the previous owner when he installed some headers off a newer model truck....so I don't know if that affected the clearance issues or not.
