Author Topic: Transfer Case Shakes  (Read 7326 times)
Offline krafty33
« on: February 06, 2010, 08:31:32 pm »
I am noticing a some shaking in my transfer case at low speed (10-20 MPH). Would bad front ujoints cause this. The only reason I am asking is because I think the joints are going bad.
Re: Transfer Case Shakes
« Reply #1 on: February 06, 2010, 08:47:16 pm »
what t case do you have?
Offline krafty33
« Reply #2 on: February 06, 2010, 08:51:26 pm »
NP 203 with part time conversion.......sorry, been a long day
« Last Edit: February 06, 2010, 08:56:10 pm by krafty33 »
« Reply #3 on: February 06, 2010, 09:00:01 pm »
well if you read one of my last post in "more snow" i also have the 203 with the kit tho but i was in 2hi if my hubs are locked it will make clucks and stuff and vibrate and in 4 lock it will do the same thing well today it broke up by the t case and the second joint not sure what failed but i see one joint just sitting in the shaft. i guess its just due to age but idk but like you said the u joint could and would cause that problem. and about your spline problem if you don't drive it that hard i don't see why 2" would hurt it but if you mud and drive it hard yeah i would like to see more
Offline krafty33
« Reply #4 on: February 06, 2010, 09:58:34 pm »
Thanks, I am gonna try the rear shaft as long as it holds. I dont do any major pullin or muddn so we will see how it goes
« Reply #5 on: February 07, 2010, 01:48:44 am »
do you have the kit on your 203? if so you don't need the front to spin any
Offline krafty33
« Reply #6 on: February 07, 2010, 09:50:12 am »
Yeah I do, the front shaft is free in unlock
« Reply #7 on: February 07, 2010, 11:49:02 am »
U-joints can cause a vibration in the transfercase but when do you feel the vibration?
Offline krafty33
« Reply #8 on: February 07, 2010, 03:09:23 pm »
Low speeds mainly...I was doing it in 4HI but I also noticed it in 2HI. It seems to do it when the hubs are locked which is makin me think joints. I also just put a 4 inch lift in and there was a spot where it said to grind the stops on the CV joint. I didnt do it cuz it looked ok....maybe its hitting a bit. I am gonna start with the joints
« Reply #9 on: February 09, 2010, 03:38:15 am »
well if it does it in 2hi it ain't the front joints since nothing spins with the kit. make sure it ain't the wheels, busted beads can do it too
« Reply #10 on: February 09, 2010, 10:23:12 am »
You probably do need to clearance grind those ears
