Starter Help
Topic: Starter Help (Read 7763 times)
4x4HighSierra
Sqaure body stud
Starter Help
February 07, 2010, 11:59:24 am »
I have a 1972 350 in my 1985 GMC and here recently i have had starter problems. I have put 2 different starters on it and shimmed it numerous different ways. What it is doing is at first starting fine with no shims then all of a sudden during cranking it will start to skip and make a grinding noise and shake the whole motor. It has done this with 2 different starters and I'm about to pull my hair out over it. And when i shim it it seems to only get worse.
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: Starter Help
February 07, 2010, 01:08:35 pm »
you have to be sure your flexplate (automatic?) is not warped and it's on correctly. Are you using a 168 tooth flexplate or 153 and starter to match?
I don't know if '72 blocks had the staggered two bolt pattern for the starters or if they are in line with the end of the block, paralell to it. Most post 72 350's have the staggered pattern. I believe the 305 are more inclined to be the smaller tooth flexplate and the parallel pattern for the starter.
Anyway, you have to make sure you are using the correct parts. Remove your dust cover under the trans and inspect the flexplate best you can. Any teeth missing? I wouldn't shim the starter blindly because it will make more problems if done incorrectly.
remove the starter and see if there are any metal shavings around the nose of the starter. Inspect the teeth of the flexplate and starter and check for wear or grinding.
Last Edit: February 07, 2010, 01:14:38 pm by SgtDel
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
4x4orbust
Re: Starter Help
February 07, 2010, 09:35:31 pm »
i've had a cracked starter mount hole do the exact same thing. next time you have the starter off clean and inspect the starter bolt holes real well.
1982 chevy K-10 SWB, 355 th350/np208. 2.5"lift, 33" swampers, headers/duals, current project
Blazin
Blazin new trails!
Re: Starter Help
February 07, 2010, 10:14:59 pm »
The 454 in my 74 Malibu used to eat starters. Found the bolt holes for the starter were ob longed etc. redrilled and helicoiled them. Solved the whole problem.
Re: Starter Help
February 08, 2010, 03:20:26 pm »
Where are you getting your starters from?
Re: Starter Help
February 08, 2010, 03:24:52 pm »
Check your ignition timing too
⌠ŻŻŻŻŻ' [☼===☼]
4x4HighSierra
Sqaure body stud
Re: Starter Help
February 08, 2010, 11:20:56 pm »
they are good starters i have kept from motors i had in the past.
Re: Starter Help
February 08, 2010, 11:38:56 pm »
Try a new starter.
⌠ŻŻŻŻŻ' [☼===☼]
Starter Help
