Author Topic: I need at least a suggestion as to my despair  (Read 14185 times)
Offline 1980c10
Re: I need at least a suggestion as to my despair
« Reply #15 on: February 15, 2010, 08:21:54 pm »
After reading this post a second time i believe you might just have a vacuum leak somewhere. check your vacuum diagrams and follow all vacuum lines and check all connections where vacuum lines may go (while it is running) you could also hook up a vacuum guage. this would explain why the engine is running poor and dying out it also explains the trans acting the way it is becuase it may not be getting the vacuum required to work the vacuum modulator on your trans.
« Reply #16 on: February 15, 2010, 09:14:47 pm »
Pull the hose off of the vacuum modulator. See if there is any fluid present in the line. Start the engine and feel for suction at the line.
Offline droe71
« Reply #17 on: February 16, 2010, 04:32:10 pm »
If i pull the hose off and find transmission fluid, what's my next course of action?
« Reply #18 on: February 16, 2010, 05:59:34 pm »
replace the vacuum modulator
Offline droe71
« Reply #19 on: February 22, 2010, 05:51:05 pm »
Hi guys,
over the weekend I had a chance to mess with the truck. I pulled the hose off the vacuum modulator and found no transmission fluid. But I did not have the truck running. I can assure you though that it was a pretty dry hose and end tube of the modulator.
I did discover however that I do have a kickdown cable and it's not connected to my carb. So that may be my problem as well. I have capped everything off the carb that does not have hose connected to it. So I know that I don't have a vacuum leak.
Does anyone know have any directions on connecting my kickdown cable? Also changing the question up a little bit. I added pcv breathers to my valve covers. Is smoke supposed to come out from underneath them?
