Author Topic: heat riser valve door is gone  (Read 4029 times)
Offline millmaster65
« on: February 16, 2010, 05:33:04 pm »
I think the heat riser valve only helps with warm up. True or False?
I am currently replacing exhaust manifold gaskets an noticed there is no gate inside the valve.
If I decide not to replace the heat riser valve, would this affect overall performance?
Re: heat riser valve door is gone
« Reply #1 on: February 16, 2010, 05:34:57 pm »
It's mainly used to reduce warm up time to decrease emissions not necessarily for driveability.
« Reply #2 on: February 16, 2010, 05:45:19 pm »
That's what I thought.
Thank You Sir
