Author Topic: my headlights will not come on  (Read 6854 times)
Offline infamouschevy
« on: February 16, 2010, 06:35:57 pm »
 ???  my headlights will not turn on all my fuses are good and all my instrument cluster lights turn on brake lights turn signals changed out my headlight switch already wasnt that so i dont know what else to check any help with the problem will be appreciated. oh ya its a 1985 c-10
infamous chevy
Offline Layne
Re: my headlights will not come on
« Reply #1 on: February 16, 2010, 06:50:01 pm »
Headlights blown? lol. Do you have power at the headlight connection? Sometimes they get cruddy and might need a cleaning.
« Reply #2 on: February 16, 2010, 06:52:31 pm »
i put direct power to the headlights and they turned on i got upraded headlights i got the conversion kit so i can just remove the bulb i got a test light its not getting power to the headlights put power is coming out from the switch
infamous chevy
Offline Layne
« Reply #3 on: February 16, 2010, 07:01:22 pm »
Check relay? I'm not familiar with this upgrade, but someone else on here probably will be.
« Reply #4 on: February 16, 2010, 07:26:05 pm »
is there a relay for the headlights where would it be located
infamous chevy
Offline Layne
« Reply #5 on: February 16, 2010, 07:37:46 pm »
Wait, do you have the upgraded wiring harness too? Or just the lights? Them lights will overheat the harness if you don't upgrade that too.
Offline Layne
« Reply #6 on: February 16, 2010, 07:42:07 pm »
« Reply #7 on: February 17, 2010, 03:04:40 am »
might be the headlight switch
« Reply #8 on: February 17, 2010, 06:32:59 pm »
got a new headlight switch is there a reay for the lights by any chance or is there a wiring diagram i can see sum where
infamous chevy
Offline Marc
« Reply #9 on: February 18, 2010, 05:38:47 pm »
check the fusible links coming off the starter - chances one of them is bad.
Offline brownie
« Reply #10 on: February 19, 2010, 11:21:08 am »
Check the high beam switch it was still on the floor in 75 right.
« Reply #11 on: February 19, 2010, 12:20:49 pm »
lol i miss that part about the switch ::) did you check the dimmer switch lol brown got to it before me. yes its still on the floor. have you tried to switch the high/low beams i think the relay is part of the headlight switch
