350 problems
Topic: 350 problems (Read 20381 times)
Re: 350 problems
Reply #15 on:
March 02, 2010, 04:03:10 pm »
2inHg with it running like crap wouldn't make me think mechanical. Check the carb
greenmonster
Re: 350 problems
Reply #16 on:
March 02, 2010, 04:08:17 pm »
Ok I'll check the carb.One more question,can you hear spark knock with a loud exhaust.Today I advanced the timing to get the highest vacuum and it gave me alot of power but it is hard to start when hot.
greenmonster
Re: 350 problems
Reply #17 on:
March 03, 2010, 07:13:42 am »
Cleaned the carb out last night,but haven't put it on yet.I pulled a plug to check the spark,it was jumping the gap and it would arc to the side of the plug.I never seen that before,is that normal.
Re: 350 problems
Reply #18 on:
March 03, 2010, 07:58:25 am »
No it's not normal
greenmonster
Re: 350 problems
Reply #19 on:
March 03, 2010, 08:09:21 am »
What would cause that.
Re: 350 problems
Reply #20 on:
March 03, 2010, 08:20:33 am »
THE CERAMIC COATING ON THE PLUG MIGH BE CRACKED CAUSE IT TO JUMP LIKE THAT
greenmonster
Re: 350 problems
Reply #21 on:
March 03, 2010, 10:47:34 am »
I'll check that.The problems started,then I did a tuneup and it still runs the same so Idoubt it's the plugs unless I got a bad plug.
greenmonster
Re: 350 problems
Reply #22 on:
March 03, 2010, 06:49:16 pm »
I checked the plugs and they are ok.The problem I found is a weak spark.The spark is orange.Any ideas!
Re: 350 problems
Reply #23 on:
March 03, 2010, 10:22:41 pm »
How's the coil and your connections?
greenmonster
Re: 350 problems
Reply #24 on:
March 04, 2010, 05:09:57 am »
I have tried 2 coils,an accel and a factory.The power wire is fine but I cant find a ground wire.I assume it grounds through the dist hold down clamp.I pulled the dist and the clamp was dirty.I cleaned the clamp and the inside of the dist but haven't put it back in yet to see if it made a difference.
Re: 350 problems
Reply #25 on:
March 04, 2010, 08:02:01 am »
No there should either be a ground wire under the cap cover or a ground strap.
greenmonster
Re: 350 problems
Reply #26 on:
March 04, 2010, 10:13:19 am »
If you are talking about the ground wire for the coil it's in there.The plug that plugs into the cap returns to the dist. so the dist. has to ground out some where.The clamp is the only way I see to ground the dist. unless I am missing something but it was running fine the way it is.I'm going to put the dist. in later,I will let you know if I figure anything out. THANKS
Re: 350 problems
Reply #27 on:
March 04, 2010, 08:45:57 pm »
It all sounds good but you can take most the parts to the parts store and get them tested. Are all plugs that way or just one
greenmonster
Re: 350 problems
Reply #28 on:
March 05, 2010, 06:19:58 am »
All the plugs are orange.
greenmonster
Re: 350 problems
Reply #29 on:
March 06, 2010, 05:51:44 am »
I tried a different distributor and still have an orange spark.I even grounded the distributor body to the battery and it made no difference.Any more ideas.
350 problems
