General Discussion
BONDO?
Topic: BONDO? (Read 7507 times)
ipetero
BONDO?
February 20, 2010, 02:07:15 pm »
Last week, the Daytona 500 got delayed for the track coming apart (pot holes forming)
, the first time the track crew tried to patch it up with a special blend of asphalt. After an 1/2 hour or more of letting it set up, they raced on it for about 20mins... The asphalt did not last too long
. They delayed the race again.. The second time, the same spot, the track crew repaired the 2 1/2 foot long 6 inch deep pot hole with 3M Bondo body filler
Surprisingly, it worked!! Shorter set up time also. I would have never thought of using bondo. Kinda of interesting..
tear it up ! !
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: BONDO?
February 20, 2010, 02:53:29 pm »
where did you hear that?
They did mention a "secret" product from 3M but didn't say what it was on TV during the red flag.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
ipetero
Re: BONDO?
February 20, 2010, 03:20:58 pm »
right now on speed, they are practicing at california, and DW pointed out Biffles sponser 3M. And now Biffles sponser 3M has the logo of "Bondo" under the 3M. And then they brought up that thats what the daytona track crew used to repair the track the second time.
tear it up ! !
joesgarage71
Wrench
Re: BONDO?
February 20, 2010, 03:25:50 pm »
I have used body filler to repair a filling that fell out, worked for about two years till the tooth rotted and had to be extracted. yea it was still in there.
Blazin
Blazin new trails!
Re: BONDO?
February 21, 2010, 01:44:35 am »
No that is hardcore!
I use body filler in interior, and exterior trim repairs all the time. As long as its painted you never know its there!
Re: BONDO?
February 21, 2010, 10:46:06 am »
I shoulda bondo'd my x girlfriends mouth shut and painted a smile there.
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
Re: BONDO?
February 21, 2010, 10:56:12 am »
ROFLMAO!
smitty77
Re: BONDO?
February 21, 2010, 01:20:13 pm »
Quote from: Blazin on February 21, 2010, 10:56:12 am
ROFLMAO!
Ditto! That IS funny!
k5blazerfan
K5 blazers will never die
Re: BONDO?
February 26, 2010, 02:54:32 am »
dumb question.. how do you remove bondo from steel?
Don't forget the tow chain!!! Might have to tow a ford home!
jaredts
Re: BONDO?
February 26, 2010, 06:43:34 am »
Quote from: k5blazerfan on February 26, 2010, 02:54:32 am
Sand or grind it out. Bondo tooth filling!! I can't imagine putting that in my mouth! Bondo works great on rotted or damaged wood too.
SUX2BU99
Re: BONDO?
February 26, 2010, 10:35:33 am »
Although it's been misused and misrepresented by countless dubious vehicle owners, I've often wondered why using Bondo (or any body filler) is considered such a no-no in the restoration world? If it dries that hard, can be finished smooth so that you can even tell it's there and does not rust since it isn't metal, what is the big deal? I could answer my own question though and say it's probably when it cracks and possibly falls out of the place it's in since it doesn't have the same expansion/contraction rates as metal. In places of extreme climate, especially cold, that can be bad.
Using it to replace a filling, man that's one for the books! The chemicals though that could and would be leaching into your bloodstream from it is dangerous I would think. But hey, if you are alive to tell the tale, than good for you!
Re: BONDO?
February 26, 2010, 02:31:59 pm »
there's nothing wrong with using body filler as long as the work is done correctly. That isn't always the case and that's why you hear of bondomobiles.
⌠ŻŻŻŻŻ' [☼===☼]
General Discussion
BONDO?
