Author Topic: Dextron/mercon as power steering fluid  (Read 13679 times)
Offline 77 step
« on: February 20, 2010, 06:48:54 pm »
Hi, been away a while... getting back to work on the '77 Chevy.  I was wondering if anyone has tried dextron/mercon in their power steering systems, and what the results were.
I know a lot of Fords (is that swearing here?  :o) use it in their power steering systems, but I am wondering if there is a difference in the seals in our systems.
Thanks!
Sean
1977 K-10 stepside under slow reconstruction.
Offline Layne
Re: Dextron/mercon as power steering fluid
« Reply #1 on: February 20, 2010, 07:18:21 pm »
You mean the atf right? I dunno I've considered doing atf in there before. Good question
Offline 4x4HighSierra
  • Sqaure body stud
« Reply #2 on: February 20, 2010, 07:23:18 pm »
ATF is fine to run in a chevy ive ran it for years in my lowrider GMC and my 4x4 GMC.
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
Offline 77 step
« Reply #3 on: February 20, 2010, 08:44:12 pm »
Thanks for the response.  I thought it would be ok, but feel better about trying it now.
Sean
Offline 87OldYeller
« Reply #4 on: February 20, 2010, 09:21:16 pm »
i have never used anything but aft in powersteering.
« Reply #5 on: February 21, 2010, 10:53:41 am »
Usage depends on seals that are used. Go with what is recommended or you might end up with some premature leaks.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #6 on: February 22, 2010, 01:37:23 pm »
Vile's right. I used it on an old 77 I had years ago, and it started leaking around the shaft.
Offline brownie
« Reply #7 on: February 23, 2010, 10:34:33 am »
the 77 came with atf as the power steering fluid.
Offline 77 step
« Reply #8 on: February 23, 2010, 07:51:17 pm »
Actually, the 77 used "GM power steering fluid or equivalent" according to my Haynes manual.  Don't have an owners manual in the glove box (imagine that ::)).
Sean
Offline bobcooter
« Reply #9 on: February 24, 2010, 10:03:47 am »
My 77 was 4 different colors when I bought it, so I don't know if it had 77 power steering pump or not. ;D
Offline 77 step
« Reply #10 on: February 25, 2010, 12:46:59 pm »
Mine is still 4 colors, at least! ;D
Sean
Offline bobcooter
« Reply #11 on: February 27, 2010, 07:09:20 am »
Mine was short, wide that was 4 different colors (mostly brown) with a set of Weld Draglites with 70's on the front and 60's on the back. It was love at first sight!
