Author Topic: 700r4 transmission problems  (Read 4874 times)
Offline HeAvYChEvY!
  • DoWnWiTdAsIcKnEsS!
    • HeAvYChEvY!
« on: February 22, 2010, 07:24:04 pm »
will shift from 1st to second but nothing after that and cant use overdrive? has a 2500 stall in it! all parts new in rebuild!!!! any possible diagnosis would be helpful!
Re: 700r4 transmission problems
« Reply #1 on: February 22, 2010, 07:38:27 pm »
Well tell us what it's doing... Not upshifting out of second? Slipping after second? TV cable is properly adjusted? Who rebuilt it and when? What was done during the rebuild?
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #2 on: February 22, 2010, 07:54:17 pm »
not upshifting after it shifts to second complete rebuild  2500 stall converter no shift kit
« Reply #3 on: February 22, 2010, 08:13:09 pm »
I will assume the linkage is installed and adjusted correctly and that in fact the manual valve and linkage are working correctly. Please answer my previous questions... Is the TV cable properly adjusted? Who rebuilt it? Did you ask the builder what they specifically did to it other than put a higher stall speed? If all of the basics check out ok, pop the governor cover off and remove the governor valve. Check the driven gear teeth and ensure the valve is moving.
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #4 on: February 22, 2010, 08:36:17 pm »
thanks i will contact builder 2moro...local retired 73 yr old man! built my 383 stroker rear end and tranny and this is the second tranny that wont upshift past second!
« Reply #5 on: February 22, 2010, 10:03:47 pm »
Heavychevy, you still didn't answer the questions so it's hard to narrow down your problem
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #6 on: February 23, 2010, 05:49:19 am »
i cant answer questions because i dont have the answers ....my buddy is going to the builders today to ask the questions for me...hopefully i can answer those questions this evening..thanks for your help and patience.
