Author Topic: Upside down steering wheel  (Read 10172 times)
Offline Squatch427
« on: February 23, 2010, 07:57:12 pm »
How would you fix this. I talked to a friend about filpping it at the rag joint on the box but the bolts are two different sizes. he said some this about flipping it at the shaft? And you cant just remove the wheel and flip it(pulled it already and had to put it all back together). oh and if this helps its a 87 column in a 76 cab.
76 Chevy Step Side 4x4 with 3/4 ton axles
96 Ford Mustang GT the Hot Rod
00 Pontiac Sunfire The Wifes Wheels
05 Chevy crew cab Silverado 4x4
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Upside down steering wheel
« Reply #1 on: February 23, 2010, 08:05:19 pm »
see if the end link adjustment is centered.
Offline Squatch427
« Reply #2 on: February 23, 2010, 11:02:50 pm »
I didn't think you could get that much out of the drag link. I'll have to adjust it and see.
« Reply #3 on: February 24, 2010, 01:52:55 am »
the steering shaft under the hood it has a c clamp if you loosen it and spin the wheel it should line up
Offline PRattenbury
« Reply #4 on: March 04, 2010, 10:49:17 am »
I was told to shorten one tie rod and lengthen the other side an equal amount to get it straight.
« Reply #5 on: March 04, 2010, 03:16:00 pm »
Why is your steering wheel upside down to begin with? If its a 4x4 just loosent he pinch clamps on the drag link (the two tie rods and sleeve that connect the steering arm to the pitman arm) and it will adjust steering wheel position.
Offline Squatch427
« Reply #6 on: March 07, 2010, 09:03:16 am »
Thanks for all the help. I noticed the drag link on the steering box side had a lot of slop so we replaced it. And while we where down there we adjusted the drag link so the wheel was rightside up. Yay killed to birds with one stone. And it didn't seem to hurt the turning radius any. thats what i really worried about with adjusting it at the drag link.
« Reply #7 on: March 07, 2010, 03:12:10 pm »
The drag link adjustment will not effect toe
