Author Topic: SES light; throws code 43... '87 Silverado w/350  (Read 19165 times)
Re: SES light; throws code 43... '87 Silverado w/350
« Reply #15 on: March 06, 2010, 06:40:43 pm »
Are you sure you were checking the timing off of the #1 cylinder wire?
Offline RMC_SS_LDO
« Reply #16 on: March 06, 2010, 07:07:00 pm »
Yup... 1st cylinder (fwd most) on the left bank... :-\
« Reply #17 on: March 06, 2010, 07:45:15 pm »
You are using an advance timing light? With the EST in bypass 0° is spec. The outer hub on the balancer can spin and throw off the timing mark so you may want to verify your tdc mark. The ESC wire is a single wire connector and is near the booster but it should be tan with a black tracer.
Offline RMC_SS_LDO
« Reply #18 on: March 07, 2010, 07:43:10 am »
This sucks...
I am now unsure if I have the right wire for the by-pass line (the one I have is brown with white stripe) and I have no clue how to verify the TDC position.  The wire I disconnected was a single wire by the booster and the only single wire I could find.  Any suggestions on back-tracking the wire?
Anyway...
I'm at the point now where I will swap the ESC today try to set the timing by light again.  If it is still running like crap at 0, I may just set it "by ear" and call it a day.
I appreciate the info!
/r
Allen
Offline RMC_SS_LDO
« Reply #19 on: March 07, 2010, 07:56:26 am »
Oops...
Minor update- I think I finally found the correct bypass wire.  It was taped to the harness coming out of the bulkhead and has a rubber boot on one end to help seal it.
No clue what I disconnected before (tan w/white wire) unless it was something for the cruise maybe.  I seem to recall reading somewhere that disconnecting the bypass wire will cause a code 42 which I don't think I had yesterday.
Will pick up the ESC module, set the timing correctly (as far as I can tell) and report back.
Thanks again for the patience; I know it is frustrating for folks trying to help when I'm screwing it up!!
Allen
Offline RMC_SS_LDO
« Reply #20 on: March 07, 2010, 02:11:41 pm »
Swapped the ESC and corrected the timing (was all hosed up- way past TDC in bypass).
Old girl is running VERY well now!  Hesitation issues are gone and no codes thrown in normal driving or under hard acceleration.
Thanks 'Vile- you were extremely helpful!
/r
Allen
« Reply #21 on: March 07, 2010, 02:56:56 pm »
Glad to help!
