Author Topic: 86 crewcab 1 ton 8 inch lift  (Read 9710 times)
Offline lifted crewcab
« on: February 27, 2010, 02:21:42 pm »
Hey guys I am looking for the correct way to lift my crewcab 1 ton 8 inches to run 38 inch tires. I do not want to use any blocks or body lift. Whats the best way and brand to run? Is a crossover steering setup needed? whats needed to run this setup? Thanks
Offline Chevalade
Re: 86 crewcab 1 ton 8 inch lift
« Reply #1 on: February 27, 2010, 03:21:52 pm »
You don't need 8" of lift to run 38's, just trim the fenders.
But if you are set on it, here is the best way to go so as not to have a stupid stiff lift.
Rear:
Diy4x - 1 ton shackle flip and switch with 6" shackles. (nets 4" of lift)
4" lift - 56" long Tuff Country rear springs.
Bilstein 5100 series shocks
Front:
Diy4x - B52 spring hangers, 6" shackle. (nets 4" of lift)
4" lift - 52" long Tough Country EZ rides (half ton springs)
SKY Off Road crossover steering for 8" lift.
Miscellaneous:
Extended brake lines (Skyjacker)
14 Bolt disc brake conversion (Diy4x)
Front extreme angle driveshaft (High Angle Driveline - talk to Jesse)
May need High angle rear driveshaft.
May need axle shims to help with pinion angle.
New gears front and back to accomodate new size rubber.
This will give you a better ride than stock, and give the lift you want.
« Reply #2 on: February 27, 2010, 05:49:16 pm »
That sounds like a good setup. I will look into pricing for this. My truck already has 4.10 gears which I think would do with the 38's. Thanks
Offline knightrider84
  • Brothers don't shake hands... BROTHERS GOTTA HUG!!
« Reply #3 on: March 02, 2010, 03:32:45 pm »
lets see some pix ! :)
Offline Engineer
« Reply #4 on: March 06, 2010, 09:38:34 pm »
Here is my K-30 with 8" Skyjacker "softride" front springs. Full 8" rearched rear springs, and a 3" body lift.
18.5/44-16.5 Gumbo Monster Mudders.
I highly recommend the Skyjacker "Softride" 8" springs. They were awesome.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
