Author Topic: edelbrock 1406 choke....  (Read 4901 times)
Offline screamin86
« on: February 28, 2010, 11:43:48 pm »
well  a few months ago a made a post about me having problems with my 1406 on my new 350 and since we've had so many crazy snow storms this year ive not touched the truck much untill about a week ago. well ive determained the main problem im having is the choke is not operating right. ive wired it up to my fuse block and grounded it to my alt bracket it starts easy but no fast idle and it stays closed it will not open like it should which is causing low rough smoking idle. if i tie the plate open it will idle alot better considering my cam and no smoke. is it possilbe the spring isnt set right inside the choke housing or am i still missing something completely lol. thanks everyone
86 ta:lm7 hot cam boltons
Offline Torque454
Re: edelbrock 1406 choke....
« Reply #1 on: February 28, 2010, 11:55:57 pm »
I had problems with the choke on mine too, it would high idle and stay that way, way  too long. I had to loosen the screws and rotate the choke housing a little. That fixed it. I don't know why you don't have fast idle (unless the screw is adjusted out too far) but it sounds like the choke is indeed staying on too long. It needs to be adjusted some.
Offline malibu795
« Reply #2 on: March 02, 2010, 02:17:46 pm »
theres a fast idle screw on the throttle linkage left side... you can adjust it.. need either a stubby screw driver or take it off and do it that way.
adam wildman
75 K25 383/400
Offline screamin86
« Reply #3 on: March 02, 2010, 03:12:57 pm »
Ill see if i can mess with it some tomarrow. That still dont explain why it will not open though :(
« Reply #4 on: March 02, 2010, 03:22:23 pm »
Your choke should be wired off of an oil pressure switch so it only energizes when the engine is running. Where in the fuse block did you tap into it? Did you verify you have B+ at the choke coil?
Offline screamin86
« Reply #5 on: March 02, 2010, 04:34:20 pm »
Into one of the accsy ports like i did my tach
