Author Topic: t- 350 leaking  (Read 3316 times)
Offline hogwild
t- 350 leaking
« on: March 04, 2010, 10:26:49 pm »
what would cause my tranny to leak out the front? i changed front seal let truck idle for ten minutes and it leaked about a quart out of the front
1986 sb 406 ci
2003 mud buggy 1300 hp 528
if my wife askes it was only fifteen bucks
Re: t- 350 leaking
« Reply #1 on: March 04, 2010, 10:32:05 pm »
Where? Behind the converter? If it is it's either the pump seal or converter seal. How is the pump bushing? Did you install the seal correctly?
Offline hogwild
Re: t- 350 leaking
« Reply #2 on: March 04, 2010, 10:55:54 pm »
all i did was r&r the seal,i had engine out so i thaught i would change seal as it leaked before,now it is worse, i believe i put it in correct ,it is coming from behind convertor. could thier be a pluged vent?
1986 sb 406 ci
Offline hogwild
Re: t- 350 leaking
« Reply #3 on: March 06, 2010, 03:24:18 pm »
well i pulled the tranny and when i pulled convertor off the seal came to, what would cause the seal to get spit out?, i had it siliconed in it didnt just fall out
1986 sb 406 ci
Re: t- 350 leaking
« Reply #4 on: March 06, 2010, 06:43:24 pm »
No need for silicone. Check the pump bushing and make sure you are using the correct seal. Install it flush and lube the seal. If it isn't going in there tight something is wrong.
