Author Topic: 87 chevy front drive shaft  (Read 6144 times)
Offline treestandjunkie
« on: March 08, 2010, 05:13:51 pm »
I need to know where to get parts to rebuild front drve shaft on my 87 k-10. the transfer case is np 205. The shaft has been sitting but is not froze up. Thanks
Re: 87 chevy front drive shaft
« Reply #1 on: March 08, 2010, 05:18:08 pm »
Any auto parts store should have what you need. Try searching on here also there's posts on where to buy the slip collar too if you need it.
Offline fitz
« Reply #2 on: March 08, 2010, 11:18:28 pm »
 Did someone swap in the 205? I've never seen a factory installed 205 in an 87 1/2 ton. It wouldn't be the first time I've been wrong, just don't want to see you order the wrong parts.
« Reply #3 on: March 09, 2010, 12:20:22 am »
i think thats all they came with, but im the same as you fitz i can be wrong
« Reply #4 on: March 09, 2010, 05:59:22 am »
87 1/2, and 3/4 ton would have had a NP 208 original. Only 1 tons got 205s.
« Reply #5 on: March 09, 2010, 05:58:02 pm »
My 87 was a 2 wheel drive converted to 4 wd with 82 K-5 blazer parts.
