Author Topic: easy 6 in lift?  (Read 10599 times)
Offline StuntManMike
easy 6 in lift?
« on: March 09, 2010, 01:18:12 am »
My buddy told me that i can take the stock rear leafs on my 87 v-10 flip them 180 degrees and put them on the front and get 6 ins of lift on the front and only have to buy 6 in springs for the rear. My question is is this true? Iv heard of this before but i have never tried it.
Thanks,
Mike
Re: easy 6 in lift?
« Reply #1 on: March 09, 2010, 01:22:44 am »
Ive never heard of it either. A popular route is buying the 6 in springs for the front, buying 2 in springs for the rear and buying ORD shackles. Their shackles will make the rear 6 in. Or keep your stock rear springs and add a 2 in block to keep stock ride.
Re: easy 6 in lift?
« Reply #2 on: March 09, 2010, 01:55:56 am »
yes you can take rear springs and put them on the front of a 88-98 v truck and get 6" of lift but you then have to put a solid axle under it then put in a 73-87 Chevy transfer case and remount spring shackles from lets say a 73-87 Chevy. but it wont work on a 73-87 that has a solid axle it has to be a independent front
Re: easy 6 in lift?
« Reply #3 on: March 09, 2010, 05:55:14 am »
So your buddy is telling you to put the leafs from the rear upside down on the front and you'll get 6" of lift?  ???
Offline fitz
Re: easy 6 in lift?
« Reply #4 on: March 09, 2010, 06:40:13 am »
If you try this I would make your buddy take it for a test drive before you drive it, it just doesn't sound right.
Re: easy 6 in lift?
« Reply #5 on: March 09, 2010, 11:25:39 am »
How would that even mount?? I think he means backwards, not upside down.
Re: easy 6 in lift?
« Reply #6 on: March 09, 2010, 04:37:51 pm »
ill have to look into those shackles. thanks...but yes i meant turning the leaf springs 180 degrees not upside down. the only reason i am considering this (if it works) is because i already have a 4 in lift with blocks and 33's. I would like to get 35's and have them not rub while offroading and do not want to buy all 4 leaf springs because if this method works ill only have to buy 2 rear springs.
Offline Chevalade
Re: easy 6 in lift?
« Reply #7 on: March 10, 2010, 12:40:14 am »
Trim the fenders.....much cheaper and a whole lot safer....what you plan on doing/have been told is wrong on so many levels. Do it right or don't be on the road.
Re: easy 6 in lift?
« Reply #8 on: March 10, 2010, 05:57:34 pm »
I think he is getting some lift alternatives swapped.
You can put rear springs on the front, but it requires new hangers and I haven't heard of doing it with lift springs.
http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=120
Offline malibu795
Re: easy 6 in lift?
« Reply #9 on: March 28, 2010, 09:06:38 am »
that and the the rear shackle flip in the back
adam wildman
75 K25 383/400
Offline bigfosty
Re: easy 6 in lift?
« Reply #10 on: April 06, 2010, 08:12:01 pm »
The easiest six inch lift will never be easy. Just a warning. I bought the cheapest lift kit I could find, blocks in the rear, springs in the front. Had to change the new ubolts for the correct ones, replace both drivelines, add stainless steel brake lines,  replace the transfer case mounts, and I think theres more that I am not remembering right now. Bottom line is you get what you pay for. But good luck.
