Author Topic: Score!!  (Read 4703 times)
Offline treestandjunkie
Score!!
« on: March 14, 2010, 04:38:35 pm »
I just picked up an 89 4x4 suburban for $400. I was just calling about the front clip to put on my 87 truck. Now I wonder what all parts will interchange??? Front/rear ends? Steering column. dash and guages. calipers and rotors. etc. The main thing i am wondering about is the front and rearends. here is a pic of the burb. The parts will be going on the truck that is my profile pic. Thanks for your help.
Re: Score!!
« Reply #1 on: March 14, 2010, 04:58:47 pm »
pretty much the front doors forward and nearly everything mechanically will swap. Good score!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Score!!
« Reply #2 on: March 14, 2010, 10:53:43 pm »
Quote
Check the RPO's--should find them in the glove box.  you should be able to tell the  axles, etc..
http://www.c2e.info/rpocodes/
Re: Score!!
« Reply #3 on: April 02, 2010, 11:22:27 pm »
Finally I went and picked up my suburban I plan on using the rearend (after I determine what ratio), front core support etc. for the headlight swap, tilt steering collumn, Windsheild, and guage cluster. Not much else I can use.
Re: Score!!
« Reply #4 on: April 03, 2010, 06:03:20 am »
You'd be surprised. Strip it good and save evrything in containers you can. The TBI system alone is a good score. What about the engine and drivetrain?
Re: Score!!
« Reply #5 on: April 03, 2010, 10:08:11 am »
It didnt come with engine and tranny but it does still have the 241-c transfer case. I know nothing about these. Good , bad , ok ????? I dont know. And what are they worth used??
« Last Edit: April 03, 2010, 10:50:53 am by treestandjunkie »
