Author Topic: Idle unsteady  (Read 5629 times)
Offline Tazman
Idle unsteady
« on: March 15, 2010, 12:04:00 pm »
My 87 is stock with fuel injection.Once in a while when at idle it will fluctuate a little,enough that the oil gage moves.Any ideas on what this is and how it can be fixed?Thanks
God BLESS AMERICA
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Idle unsteady
« Reply #1 on: March 15, 2010, 12:05:55 pm »
is it when it first starts up cold, or after driving a bit w/ a warm engine?
Re: Idle unsteady
« Reply #2 on: March 15, 2010, 12:48:08 pm »
Check for vacuum leaks and check the tbi base gasket
Offline 1980c10
Re: Idle unsteady
« Reply #3 on: March 15, 2010, 08:34:35 pm »
Any codes? You could check your idle air control valve. Any other symptoms?
Re: Idle unsteady
« Reply #4 on: March 16, 2010, 10:39:25 am »
Also does the volts drop any ?
Offline Tazman
Re: Idle unsteady
« Reply #5 on: March 16, 2010, 11:20:17 am »
It does it when warmed up mostly.Thanks for the ideas I will check those out.
God BLESS AMERICA
Re: Idle unsteady
« Reply #6 on: March 16, 2010, 08:09:29 pm »
The reason I asked about the volt is when my 94s alt was going up it would stop charging and the truck would run off the battery causing it to idle erratically
Offline Tazman
Re: Idle unsteady
« Reply #7 on: March 19, 2010, 11:31:24 am »
I will check that,I do not have an alt gage.Thanks
God BLESS AMERICA
