Author Topic: evap canister, carburetor, connections and more!!!  (Read 5945 times)
Offline ruedasr
« on: March 15, 2010, 10:06:16 pm »
Hi! newbie to the forum and newbie to cars!
I have a 81 1/2 ton with a 350 and th 350.  I have a carter afb 9637 and want to switch to an edelbrock 1406.  The carter has an extra port closer to the electric choke (ie not the fuel line).  The edelbrock carb does not.  This line is connected to the evap canister.  I would think it should have been connected to the egr valve which is already long gone!
As you can tell with my dilemma, what do i do now? Is that connection correct? Do I have the correct carburetor?  Can I plug that line that went into the carter carb?  Can I plug the rest of the lines and keep the fuel tank vented?
I also would like to know what the canister SHOULD be connected to...  I believe there are 4 ports on the canister.  I have read to rip it out
Offline 1980c10
Re: evap canister, carburetor, connections and more!!!
« Reply #1 on: March 15, 2010, 11:57:58 pm »
My canister killed my carb after it imploded. You should be able to find a vacuum diagram and see where all lines go.
Offline SUX2BU99
« Reply #2 on: March 16, 2010, 10:31:28 am »
My gas tank was connected to my canister but my canister was not connected to my carb and has been like that for about 10 years. I've had the truck for 6 and haven't noticed anything because of it. I don't plan on reusing my canister and so far, just have the vent hose from the gas tank open-ended. I don't know the implications of running like this.
