Author Topic: Transmission Leak  (Read 3064 times)
Offline three8six
Transmission Leak
« on: March 15, 2010, 11:20:00 pm »
I have a transmission that leaks from the between the engine the and trans and was wondering what could be done to resolve this?
Re: Transmission Leak
« Reply #1 on: March 16, 2010, 06:47:40 am »
Remove the trans and check the converter neck. Check the pump bushing and replace if necessary. Replace the converter seal. Check the pump seal around the circumference of the pump too. If it's leaking drop the pan and remove the filter & TCC solenoid. Remove the pump and replace the gasket and seal.
Offline three8six
« Reply #2 on: March 16, 2010, 12:16:32 pm »
thanks
