Author Topic: Tach wont work  (Read 7473 times)
Offline 1981 ss chevy
Tach wont work
« on: March 20, 2010, 05:21:48 pm »
I just installed a new tach in my truck i had old wiring from my old tach and i tried the tach first to make sure it worked.  It does.  So i decided to rewire the whole works, ground, hot lead, disty line, and one to the lights.  Now once i got done wiring it it wont register anything while truck is runing only it lights up.  I have a good ground and a good hot line its wired in with the ignition.  I thought maybe it was my disty cab so i put on a new one still nothing.  So i went through my wiring again its all good to go but still no luck. I dont kno what else to do you guys have any ideas??
Offline Armor
Re: Tach wont work
« Reply #1 on: March 20, 2010, 09:46:06 pm »
i dont know the brand you have, but one i had(sunpro) once had the tach wire disconnected from the board inside the gauge, as if it was pulled hard and broken, dont know if it applies but just a thought
Re: Tach wont work
« Reply #2 on: March 20, 2010, 11:01:28 pm »
You hooked up to the negative side of the coil right?
Re: Tach wont work
« Reply #3 on: March 21, 2010, 01:25:06 pm »
no i have it grounded inside my cab its always worked this way
Offline howlinwolf
Re: Tach wont work
« Reply #4 on: March 21, 2010, 02:00:03 pm »
i think he meant the signal wire, but if its an 81 the coil is on the distributer cap right?
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Re: Tach wont work
« Reply #5 on: March 21, 2010, 08:16:02 pm »
correct the disty has a lil tach outlet and today i went to put gas in and it worked right when i started it and then as i was driving it just all at once quit working so i jiggled all the wires still nothing
Re: Tach wont work
« Reply #6 on: March 21, 2010, 08:28:24 pm »
Check your connections
Re: Tach wont work
« Reply #7 on: March 22, 2010, 08:06:49 pm »
i did they are all tight and right still nothing is it possible for a wire to be bad or burnt?
Offline howlinwolf
Re: Tach wont work
« Reply #8 on: March 28, 2010, 02:14:20 pm »
its possible that the wire has a short, or the tach has a short. is it new or reused from something else. (i ask because ive had my tach on 3 vehicles.)
Re: Tach wont work
« Reply #9 on: March 30, 2010, 08:25:19 am »
ya i've had this tach in two trucks and a monte, but i figured it out my hot lead wire was bad i tried using new wire and now it works like a champ
