Author Topic: 78 chevrolet linkage issue after lowering tranfer case  (Read 3676 times)
Offline chadt256
« on: March 22, 2010, 09:08:48 pm »
alright.. i lowered my t-case an inch so the front d-shaft would hook up ... after doing so my drive and reverse and park linkage will not engage it just makes a small grinding sound... any ideas welcome?
Installed 6 inch suspension thats why im having to lower t-case..
Re: 78 chevrolet linkage issue after lowering tranfer case
« Reply #1 on: March 22, 2010, 11:23:56 pm »
Loosen the jamb bolt on your shift linkage. Put the trans in park, and the shifter in park. Tighten it, from there you might need to tweak it a bit, but this gives you a start point!
