Author Topic: Another drive shaft question  (Read 2782 times)
Offline krafty33
« on: March 24, 2010, 04:44:12 pm »
I have a 76 K10 with a 4" lift.As some of you know, when I went to bolt the rear drive shaft back up I noticed the splines were sticking out of the slip yoke a bit. I still have about 2" of spline inside the yoke. I noticed a little play when I push the shaft up and down. When I twist it, it is tight. Do you guys think this is anything to be worried about?
Offline liftedchevys87
Re: Another drive shaft question
« Reply #1 on: March 27, 2010, 10:59:04 am »
Well technically what ever is sticking out, thats less area that twisting force is getting to your rear end. I would just run it for now and get a longer one and have it balanced, etc in the mean time. I dont think it really will effect much though.
- 87 1/2 ton 350 4x4
- 78 1/2 ton 454 flat bed 2wd
« Reply #2 on: March 27, 2010, 11:23:51 am »
Reverse the spacers on your crossmember so you have the transfer case lower about an inch.
