Author Topic: lubrication question.....  (Read 3340 times)
Offline BIG CHEVY
  • FOLLOW ME,,,, ILL TRY IT.
« on: March 27, 2010, 04:35:22 pm »
EXACTLY WHAT KIND OF LUBE DO YOU PUT IN THE REAR CHUNK OF MY TRUCK? ALSO DO BOTH TAKE THE SAME THING?
I HAVE A 79 K-10 WITH NP 203.    NEW TO ME SO I AM GONNA MAKE SURE ITS DONE RIGHT SO FOR PEACE OF MIND
I WANT TO BE IN AGREEANCE WITH ALL OF YOU.  THANKS GUYS.
Re: lubrication question.....
« Reply #1 on: March 27, 2010, 04:36:29 pm »
Do you mean the read end? 80w90
Offline BIG CHEVY
« Reply #2 on: March 27, 2010, 07:10:07 pm »
YES BOTH REAR AND FRONT.   ALSO THE FRONT HAS A DRAIN PLUG AND A HOSE COMING OUT OF THE TOP.
THE REAR HAS NO PLUG AND THE SAME HOSE COMING OUT THE TOP.   WHAT GOES IN EM?   AND WHAT ARE THOSE HOSES?
HOW DO I CHECK THE REAR OR ADD/REPLACE?
« Reply #3 on: March 27, 2010, 08:09:47 pm »
Those are both 80w90. If it's a posi in the rear you'll need limited slip additive. The hoses on top are breathers and they just vent the housings. Just remove the fill/check plug on level ground. the level should be just about to the bottom of the fill plug. The fill/check plug on the rear is not on the cover, it's on the front side and is a 3/8" drive square so just use a 3/8" ratchet to remove it. Make sure you clean around the check plug before you remove it.
« Reply #4 on: March 27, 2010, 11:29:31 pm »
You can drain them and replace with synthetic oil.
By the way all caps. is considered yelling!
