General Discussion
obsolete GM part# SPRING set
Topic: obsolete GM part# SPRING set (Read 4468 times)
Zeked
March 27, 2010, 09:51:27 pm »
Im looking for info on an obsolete GM spring set # 15151110 it was for a
1990 GM truck chassis that is part of my motorhome.... A Champion Ultrastar
I have taken a lot of numbers off of the spring pack but the local wrench
got me the above number.... I just cant find ANY reference to it.
Any Ideas?
Often Wrong......Never in Doubt!
Re: obsolete GM part# SPRING set
March 27, 2010, 09:53:30 pm »
rear leaf springs?
Zeked
DOH!
March 27, 2010, 10:09:46 pm »
Sorry Vile.... Another confusing post.
Yes, rear leaf springs off of a Chevy truck.
Odd enough the motorhome has a different number of
leaves right/left with an addl leaf on the drivers side.
Cant tell if one was broken, or if this was done to
offset black water.
Regards
Zeke
March 27, 2010, 10:42:57 pm »
I would recommend a new spring pack for both sides. Your best bet is to go to a spring shop and have them match them up.
Blazin
Blazin new trails!
March 27, 2010, 11:20:05 pm »
Year, make, model. Width, leaf thickness, how many leaves, plus the overload on the bottom. Length from the center bolt to each end. U bolt ID, length, and wire diameter should be all you need at a spring shop.
General Discussion
