Author Topic: drip rail screws  (Read 7988 times)
Offline Armor
drip rail screws
« on: March 31, 2010, 07:52:58 am »
I'm trying to get my drip rails to seal on the cab, the problem is that the screw holes were practically striped by the PO, is there anything i can do to keep the screws tight? was thinking something like a drywall plug or emblem plug from the fenders.
any thoughts would be great, ive hit the wall on this one.
Re: drip rail screws
« Reply #1 on: March 31, 2010, 07:56:17 am »
fill them with epoxy and drill them out to a smaller size
Offline jonah_cfh
« Reply #2 on: March 31, 2010, 09:29:27 am »
you could always just shave them. i think they look better w/o them anyway
1983 Chevrolet C10
1996 Ford Crown Victoria
Offline lucki17
« Reply #3 on: March 31, 2010, 05:39:26 pm »
cant you just use a shallow metal screw with bigger threads but the same head size?
« Reply #4 on: March 31, 2010, 09:14:27 pm »
If its not painted yet you can tap the screw holes flatter. This will tighten up the hole.
Offline low budget
« Reply #5 on: March 31, 2010, 09:24:01 pm »
Vile,
Will paint stick to epoxy if you leave the drip rails off?
« Reply #6 on: March 31, 2010, 10:33:22 pm »
If you were leaving them off, I would weld the holes, grind them flat and smooth over them. I beilieve the original post here was to resolve a few screws that won't tighten down on a truck that already has paint, but that's just an assumption.
Offline Armor
« Reply #7 on: April 04, 2010, 07:40:20 am »
ya its already done, i like the driprails, just cant tighten them down enough as some screws are spinning, so epoxy should do the trick? ill try that this week after my rear main seal replacement. thanks a ton
Offline KY..Rob
« Reply #8 on: April 05, 2010, 09:04:40 pm »
I had the same problem. My truck didn't have any when I bought it. The rails I got from the junk yard had bad screws and were rusted and broke off when I tried to remove them. I used 1/4" Zip screws (The head is a 1/4") ran them in with a screw chuck and finished them off with a 1/4" wrench, I just took my time and eased into them and they tightened right up.
Rob..
