Author Topic: Front & Rear Windshield Removal Info Request  (Read 16924 times)
Offline Jeff
« on: April 02, 2010, 06:24:55 pm »
('74 short bed, step side/resto-mod) Should I pay a professional to remove the front and back glass?.  I have removed everything but the bezel, column, throttle cable, and heater.  I'll remove those items hopefully tomorrow.  I just haven't been able to figure out how to remove the glass without breakage.  I'm preparing the cab for a visit to the sandblaster.  Thanks for your advice.
Re: Front & Rear Windshield Removal Info Request
« Reply #1 on: April 02, 2010, 07:46:36 pm »
Do it yourself.
On the front, pull the metal locking clip and then pull out the locking strip, then gently push the window out..
On the back, get inside and flip the top corner of the gasket down then put a little pressure on the glass and slowly work it out.  Have someone on the outside if you think you will drop it.
« Reply #2 on: April 02, 2010, 09:05:56 pm »
Remove the locking zipper strip, then cut the rubber with a utility knife that still remains holding the glass in.
Offline Jeff
« Reply #3 on: April 02, 2010, 09:44:26 pm »
Thanks Capt'n & Blazin!  I just got the front windshield out about 10 minutes ago.  But the rear windshield has got to be "welded in-place".  Should I use a utility knife, and sacrifice the gasket?.  Seam's to be the lessor of evils, I'd rather not break the glass.  Thanks again, for your help. ;D
« Reply #4 on: April 02, 2010, 10:24:15 pm »
I wouldn't cut it.  You should be able to get it out.  the beginning is the hard part.
« Reply #5 on: April 03, 2010, 06:08:59 am »
If the rear rubber has the zipper they come out so much easier. If it's the solid rubber it's a little harder. If the rubber is hard as a rock just cut it and replace the gasket to avoid cab and window damage. If it's not use some windex and a piece of 16 gauge wire. Run it between the channel and the rubber. Once you get it working push lightly on the window. Once it starts to pop out the rest is easy.
Offline Jeff
« Reply #6 on: April 03, 2010, 08:44:22 am »
Thanks Vile;  It's a single, but very hard rubber gasket installed on the rear glass.  I've pulled, tugged, pushed, etc..  I've got some 14 ga. stranded wire, that might work with the windex.  I'll give it a try today, if not, I'll dissect the gasket.  I don't have much more work to do, and the cab can be removed from the frame, and off to the sandblaster.  Thanks again!!!
Offline Jeff
Front & Rear Windshield Gasket Rust
« Reply #7 on: April 08, 2010, 04:49:32 am »
After removing both front and rear windshields, I've discovered some "bad" rusty areas.  Can this be cut-out, and new steel welded in it's place?.  Or, spray "rust converter" on the areas (exterior), and fill the hollow holes with "all metal"?.  Thanks in-advance for your help.
Offline Jeff
« Reply #8 on: April 09, 2010, 04:47:08 pm »
I really appreciate all the great info that I've receive thus far......Please!!!, anyone care to comment on the last post, please? ;D
« Reply #9 on: April 09, 2010, 04:53:54 pm »
How bout some pix so we can see how bad it is? Take a wire wheel and clean it all out good. If it's rotted you will have to do some repairs but it's hard to give that kind of advice without seeing it.
« Reply #10 on: April 09, 2010, 04:54:21 pm »
You can repair it (what I suggest) but there are no patch panels for this.
Check this post: http://forum.73-87chevytrucks.com/smforum/index.php?topic=14132.30
Offline Jeff
« Reply #11 on: April 09, 2010, 10:21:20 pm »
Thanks for the responses.  I just left the garage, I'll try my best to post some photos tomorrow.  I'm currently in the process of removing the heater box from underneath the dash.  I've found a lot of rust that was painted-over, and not properly repaired.
Offline Jeff
« Reply #12 on: April 10, 2010, 10:18:53 am »
I'm "throwing-in the towel".  I can't resolve the "how to's" in order to resize a jpg file photo from my "CrackBerry" to a file less than 128k.    I sure appreciate all the valuable info given.  I've tried to send just one photo (taken with the CrackBerry), and the jpg file exceeds 128k.  After I calm down, and finish my "honey-do's", I'll try later to send some photos. ???  I do not have a PC, I've got a Mac.
« Reply #13 on: April 10, 2010, 10:31:47 am »
email the pix to me if you want and I'll host them for you.
« Reply #14 on: April 11, 2010, 08:00:37 am »
Here ya go
