Author Topic: Head light issues  (Read 4838 times)
Offline Ole Blacky
Head light issues
« on: April 04, 2010, 09:53:29 am »
Well my head lights quit working the other day and I can't seem to find the problem I have no power at the headlight switch but I have checked all the fuses and they are good. Any pointers it's a 85 k10
Re: Head light issues
« Reply #1 on: April 04, 2010, 10:04:29 am »
Which headlight set up do you have? Do you have B+ at the fuse? Which cavity did you check on the headlight switch? Are you sure there's no B+ at the headlights?
Offline Ole Blacky
« Reply #2 on: April 04, 2010, 10:19:22 am »
I'm not sure to be honest I checked it for power on the bigger red wire running to the switch also my hi/low beam swith went bad a while ago so I have just been running with the high beams and then they just all of the sudden quit working
Offline Ole Blacky
« Reply #3 on: April 04, 2010, 10:33:27 am »
Now that Im thinking about it I do have power at my switch because my parkin lights work so I am guessing  maybe my dimmer switch went bad?
« Reply #4 on: April 04, 2010, 08:39:38 pm »
Offline Ole Blacky
« Reply #5 on: April 04, 2010, 10:15:26 pm »
Ya I think there might be but I found my problem it was the dimmer switch. Thanks for the help
