General Discussion
will this rebuild kit work on a 93 5.7 350?
Topic: will this rebuild kit work on a 93 5.7 350? (Read 6745 times)
gold84gmc
April 12, 2010, 09:09:34 pm »
i might be getting a 93 gmc with a 5.7 tbi, i was wondering if i could use this rebuild kit on that engine
http://www.summitracing.com/parts/SUM-SBCKIT1-000/
92 buick century custom 3.3L
Re: will this rebuild kit work on a 93 5.7 350?
April 12, 2010, 09:21:17 pm »
if the 93 is a one piece rear main I would say not.
gold84gmc
April 12, 2010, 09:31:17 pm »
so the pistons and the bearings wouldnt work eather?
April 12, 2010, 09:41:45 pm »
Most of it will, but some of the seals won't the specific crank bearings.
gold84gmc
April 13, 2010, 09:15:59 am »
how can i find out exactly what will and what wont work?
April 13, 2010, 09:52:15 am »
Basically most of the gaskets are wrong.
http://www.summitracing.com/parts/FEM-MKP6156A-000/?rtype=10
Just get the correct sizes
⌠ŻŻŻŻŻ' [☼===☼]
gold84gmc
April 13, 2010, 01:30:31 pm »
so if i get a gasket set for that engine, i can use all the other parts that are in the kit that i have?(pistons,bearings,freeze plugs,rings,oil pump)
gold84gmc
April 14, 2010, 07:41:35 pm »
can someone please respond to my last question? because im going to look at the truck tomorrow and if i need to buy more than that gasket set to rebuild the engine then im not gonna buy the truck
Donut
April 14, 2010, 08:08:50 pm »
How about listing the old rebuild kit in Uncle Henry's or something? Then use the $ to buy the right kit.
I haven't used either kit, just trying to throw out some suggestions.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
gold84gmc
April 14, 2010, 09:01:31 pm »
i would do that but i dont think i would be able to sell it quick enough and the rebuild kit now is probably $250, and i paid $199 for my kit
April 15, 2010, 03:01:55 pm »
You'll have to tear the engine apart to see. Do you know the bore diameter and the condition of the cylinders. Do you know if the mains and rods are in good shape? Are they standard?
Basically as far as gaskets you'll need the oil pan, rear main, intake, valve cover and valve seals. Everything else should work.
⌠ŻŻŻŻŻ' [☼===☼]
gold84gmc
April 17, 2010, 09:02:28 am »
well it doesnt matter now anyways because the guy sold the truck to his brother in-law the night before i was going to look at it
General Discussion
