4 Wheel Drives
Transfer Cases and Front Drivelines
Desperatly need some np203 Mile Marker 501 kit part time install help - thanks
Topic: Desperatly need some np203 Mile Marker 501 kit part time install help - thanks (Read 46222 times)
74k20
April 18, 2010, 07:54:42 pm »
Sorry long, but felt I needed to go into a bit of detail of my problem.
Pretty frustrating day working on the truck. Could use some advice and assistance please. I'm taking break and will regroup myself and tackle it during the evenings.
So I'm working on my '74 k20 350/th350/np203, and "TRYING" to install the Mile Marker 501 part time kit, with no luck.
Instructions seem very vague and doesn't quite match my specific t-case. 1st off my t-case seems to be the original '74, with a one piece cast tail cone (and a t-case frame connector). Reason I bring this stuff up is, I just took apart a '77 k10 with th350/np203, but it had a different cross member and no t-case frame bracket. BUT most importantly it has a two piece tail cone like the instructions show.
So thought I got around the different tail cones, but then the Mile Marker 4 piece gear pieces do NOT mesh with the t-case gears.
a) Now should I just take the tail cone off the '77 np203 and install it on my '74 case?
b) However is there a difference in shafts between the 1/2t and 3/4t?
c) I don't really think this will help out my different gear mesh issue either.
d) Mile Marker instructions state to use a spacer from a 75 and newer if my t-case is a '73 or early '74. How the heck do I get this spacer since it was NOT included in the kit. I'm not about to tear apart my 77 t-case and ruin it for one little spacer. Complete tail piece fine, but not one little spacer.
I'm at a loss right now. Any ideas?
Re: Desperatly need some np203 Mile Marker 501 kit part time install help - thanks
April 18, 2010, 08:12:23 pm »
There's a lot of how to's on this
http://coloradok5.com/milemarkerpt.shtml
⌠ŻŻŻŻŻ' [☼===☼]
74k20
April 18, 2010, 08:25:22 pm »
I actually took my computer out to the garage using that website info. It helped a little, but didn't really explain why the gears don't mesh together, or anything about the little spacer difference.
The spacer in question is at the bottom of the picture in the center. "If" this was my only issue, I would have only had a small 1/8" ish gap. But I had about a 1/2" gap where the Mile Marker gears did not mesh into the tail shaft gears (maybe it's called the output shaft).
You can see the MM gear pack in the gear pack assembly, and it faces and into the output shaft during install of the tail piece correct?
Last Edit: April 18, 2010, 08:31:25 pm by 74k20
74k20
April 18, 2010, 10:58:50 pm »
Had to go out in the garage for another fresh look, in my pj's.
BINGO. The new MM gears "TRAP" in the shaft that needed to be removed from the tail housing. So I took the cage apart and installed the tail shaft and now I'm back on track. Sure didn't see the one line that said "remove shaft and now install into the cage". Even stayed in my pj's, hands smell like oil again though.
Guess I just needed a fresh look and a tired brain to figure it out. Off to bed a bit happier.
smitty77
April 19, 2010, 04:34:17 pm »
Quote from: 74k20 on April 18, 2010, 10:58:50 pm
Sometimes you just have to walk away for a few hours and then you see the light and wonder why you wasted more time than you took "off" looking at it and not getting anywhere.
April 19, 2010, 07:25:54 pm »
I did my first one of these when I was 17 in my buddies driveway in the dark with a 12 pack of black label. Needless to say the truck stayed there over night but we finished it the next day and somehow it worked lol. Sometimes it takes a few tries to make things click and walking away or having a cold one is usually is all it takes then things just fall into place. Nevertheless, glad you got it.
⌠ŻŻŻŻŻ' [☼===☼]
74k20
April 19, 2010, 09:50:56 pm »
Thanks for the support everyone. Feels better now that I'm close. Now I just need to finish up in the evenings between 2 kids in baseball.
Still a bit confused about what year "spacer" (early or late model '74) I have, what to use, and/or where to get one if I do need a 75 and newer spacer. Napa had NO clue what I was talking about, so I emailed Mile Marker. I don't want to "try" to install the assembly without feeling confident in what to do.
Thanks for all the assistance and support.
frickenbored
383 Beast
April 20, 2010, 08:35:14 pm »
You are in luck, I just installed the 501 kit last week, so if you haven't figured it out yet heres some info...
First off you have to flip the dif cross over so the lip faces towards the back of the transfer case, like so:
Then you have to take the shaft out of the tail cone and first put the four gears on the shaft and then the outer drum around the gears. It all has to be one piece before you put it in the t case because the tangs on the tops of the mile marker gears lock the shaft in place, heres a pic of how it has to look before you install it:
Dont forget to use grease to hold those 15 needle bearings in the shaft as seen in the first pic.
As for that spacer it goes in the actual transfer case under the new torrington bearing that comes in the kit. Heres a pic, the spacer is under the mile marker bearing seen covered in grease:
Heres what it should look like before you put the tail cone back on, dont forget the endplay shims, usally two shims seems to work:
let me know if you have any more questions.
Last Edit: April 20, 2010, 08:37:54 pm by frickenbored
frickenbored
383 Beast
April 20, 2010, 08:36:47 pm »
lol i guess i didn't read the post where you found out that the shaft is held in place by the gears...
74k20
April 21, 2010, 12:00:01 am »
Thanks for the above pictures, but I finally figured out that part after taking a break. Today however was my main headache and adventure. I called 2 trans shops, 1 4x4 shop, 1 parts store, and Mile Marker direct. Everyone was trying to help, but not even Mile Marker gave me the information I NEEDED to finish. It all came down to one trans shop here in Portland that called 3 other shops and found my answer. Then he found the part in his shop and GAVE IT TO ME - FREE. WOW, what service and an awesome guy.
The attached picture is of the spacer issue that I needed to track down. The right side is out of my '74 and note the shoulder step. The left is what the MM 501 kit needs, and matches the bad picture in the Mile Marker instructions. EVERY diagram break down of the np203 all show a no step version. Not one internet 501 installation guide/instructions/help info show this spacer in a write up. So nobody understood what I had and/or needed. Even the picture above with the red arrow hides the true spacer.
Thanks frickenbored for the above information, you did a great job.
I hope this info pops up in the search to save someone else down the road from this problem. But most importantly be able to see the old version ('73 & early '74) and required newer version side by side. Still don't know where a person would get this proper sleeve for the MM501 kit. I got VERY lucky to find a GREAT shop willing to help a guy out.
74k20
April 22, 2010, 09:32:38 pm »
NO FUN AT ALL. Wish I would NOT have started this and about done and ready to put it back to stock.
I do NOT feel comfortable about the new MM washer/flat bearing/washer sandwich. The 1st washer to install barely contacts the big gear. The spacer I fought to get, has slope and appears to just float behind this new washer and the needle bearing. NOT sure this is correct.
So I did a dry install to see if I can feel some sort of "play" to see where I stand with the washers. Have to install everything, bolt down the housing, then check. I felt NO movement, so guess time to try and remove a washer. Well EVERYTHING has to come competly apart and set back on work bench to disassembly the housing again. What a royal pain.
This just CAN'T be this hard of a project. got to be a heck of a lot of trucks out there with this done. It appears to be the 1 piece housing that's the headache.
Any more ideas out there on what to do besides just installing over and over and over
I'm about to go back to stock config and put the hubs back in box and wait for a 205 to come along.
Thanks,
MJ
April 22, 2010, 10:16:59 pm »
How about a 208? They're cheap and readily available.
⌠ŻŻŻŻŻ' [☼===☼]
74k20
April 22, 2010, 10:54:21 pm »
This np203 has been working just fine for my grandpa for 36 years. Now that I have it and gas a "tad" more today, I was just hoping for a little better MPG, hp feel, and little more street friendly for the wife. Besides so many have already been converted that this project shouldn't be this difficult.
So tomorrow evening I'm going to attempt to remove the 2 piece housing off the 1/2t '77 np203 and see if I can install it onto my '74. This might finally make the install match Mile Marker directions and the Coloradok5 instructions.
Otherwise come Saturday morning it's going back to full time again.
Thanks and please keep the ideas coming. Someone has to have done a 1 piece tail housing install and could share a trick or two. I'm sooo close.
MJ
74k20
April 23, 2010, 09:24:03 pm »
Last post on this on-going thread. I finished it up tonight. Took a few intalls, and un-installs, but I got it. Ended up only using the two thin washers, that's all. After mocking and ending up with about .010 endplay, I sealled it up and finished it. After the sealer and tightening down, ended up with a tad more endplay then I was shooting for at about .015-.020. But more is better then not enough.
Took it for a drive and it does feel nice. Does "clunk" a tad more then I would like while back/forth, so either the shaft kit or a 205 will be my next upgrade. BUT NOT NOW. I'm done for awhile with this t-case swap.
Yea I made a couple errors due to lack of understanding and can only blame myself. However some extra clarification on a few areas would have DRASTICALLY helped me along.
Couple more weeks and all new springs, shocks, suspension stuff. That should all be bolt on/off.
Thanks all. Over and out - done with this project.
YIPPY.
MJ
mechanic58
June 26, 2013, 04:48:57 pm »
Sorry to dig up an old thread, but this is the only thread I can find anywhere that details the differences in the early and late 203 differential tailshaft spacers. The pictures included here are great - however no one posted up the difference in the height between the two spacers. I was wondering if anyone knows what it is? I have an early 203 that I am installing a mile marker 501 in and I need to know how thick that spacer should be. I am going to use my original stepped spacer but I am going to have it machined to the correct thickness.
I like junk
4 Wheel Drives
