Author Topic: odometer rollback  (Read 16634 times)
Offline markdilljr
  • Me on Hopper "Covered"
odometer rollback
« on: April 20, 2010, 11:38:22 am »
I am putting a new gauge cluster in my 84 C-10 and I want the new odometer to read what the stock odometer was at. I am not trying to do anything illegal or get over on anyone I just want the new one to match what the truck has on it milage wise, Thank you to anyone that can help
Ride Rank, Make Bank
Re: odometer rollback
« Reply #1 on: April 20, 2010, 01:36:25 pm »
I did the same thing, except with autometer gauges. go buy a speedo cable, cut it about 6 inches from the gauge. Cut the black cable housing shorter so that the actual cable is sticking out. Use a drill to spin the cable. You will be doing this for awhile.
Because I did this with autometer gauges and not stock, I dont know if you can access the back of the odometer and do something different.
« Reply #2 on: April 26, 2010, 11:45:38 pm »
I wouldnt worry about legalities on these trucks.  They are generally beyond their limits.  you should be able to rotate it with a drill, but pulling it apart and doing it is tricky.
Offline Da67goatman
  • Burban
« Reply #3 on: April 27, 2010, 06:01:06 pm »
On that topic, does anyone know how to adjust the electronic odometer in 1989-91 suburbans?  I just changed drivetrains and gauge clusters and want to match the odometer new to old.
<Pitcrew>
« Reply #4 on: April 27, 2010, 09:40:19 pm »
My 89 K5, 90 Burb and 91 Crew all have mechanical odo's
« Reply #5 on: April 27, 2010, 09:56:53 pm »
Capt, did they offer a trip odometer in any of the mechanical speedometers?
Offline Da67goatman
  • Burban
« Reply #6 on: April 28, 2010, 06:51:54 pm »
I got the gauges out of a 1991 GMC Suburban and it has electronic odometer, speedo and trip.
<Pitcrew>
« Reply #7 on: April 28, 2010, 11:15:25 pm »
yes the trip meter was an option.
Da67goatman post a pic.  If it is electronic (I have never seen a 73-91 with it) there is no way to change it.
« Reply #8 on: April 28, 2010, 11:22:04 pm »
Great, I need to find one then
Offline Da67goatman
  • Burban
« Reply #9 on: April 29, 2010, 09:45:40 am »
Here's the connection on the trans tailhousing, it goes right in place of the mechanical cable style.  The gauge end of the wires is part of the main plug-in connector that goes right into the cluster.
<Pitcrew>
Offline jaredts
« Reply #10 on: April 29, 2010, 11:15:01 am »
This may sound silly, but can you turn the ignition to "on" without starting the engine and rotate the speed sensor with a drill and roll the miles that way?  Just a thought for the electronic speedo.
Offline Da67goatman
  • Burban
« Reply #11 on: May 03, 2010, 12:13:29 pm »
Update: Here's the gauge end of the electronic speedometer.
<Pitcrew>
